Big cam low vaccum
Old Apr 16, 2018 | 05:49 PM
etweeks's Avatar
Big cam low vaccum
HI Have 69 charger 440 low vaccum I need to add vane style power brake booster any suggestions on which would be the best cvr leeds or master power ? Thanks for any info.
Old Apr 16, 2018 | 07:36 PM
Are you sure you need that much vacuum? Or will a canister with another check valve work ok?
https://barkerengines.com/product/br...powder-coated/
Old Apr 17, 2018 | 09:10 AM
etweeks's Avatar
Good Morning Bob, I don't know if another canister would help I only have 13" of pressure at the manifold it should 15" at bare minimum 18" to 22" would be great. The power brake's are rock hard know. Thanks Thomas
Old Apr 17, 2018 | 11:26 AM
How about an electric vacuum pump Check with Summit racing
Old Apr 17, 2018 | 12:03 PM
etweeks's Avatar
Thanks that's my next option Can't figure which none to buy?
Old Apr 17, 2018 | 01:25 PM
My son likes the ones in the newer Mustangs.
Old Apr 17, 2018 | 08:43 PM
http://ssbrakes.com/i-10093987-elect...ist-28146.html
Old May 30, 2018 | 04:29 AM
ZEN357's Avatar
I would go with another canister and vacuum pump for the camshaft.
Old May 30, 2018 | 06:01 AM
Archer's Avatar
Thomas -
I've been running about 12" at idle for the last 40 years on my 440 and have no problems with the breaks or anything else that's vac assisted.
If you're having issues, something else is going on.
BTW - I have a vac gauge on my instrument cluster, so I know exactly what the pressure is in real time.
Old May 30, 2018 | 11:49 AM
etweeks's Avatar
low vacuum
Thanks I went to vane style vacuum pump it seems to help. Thomas
DieselJeep
Sep 27, 2018 08:22 AM
etweeks
Member question and comments about MoparForums.com
Apr 16, 2018 07:36 PM
Coronet 500
Oct 9, 2013 02:50 PM
lunati318
Apr 12, 2011 02:39 PM
Monaco383
Jul 16, 2009 12:53 PM
