Block Huggers
Old Jun 20, 2010 | 07:49 PM
Barfly's Avatar
Block Huggers
My 340 is a tight fit in the Dakota due to the steering column shaft.
I'm toying with the idea of getting some block hugger headers.
My problem is there run around $150 a pair and I'm not sure I could fit them in there.
Has anyone had any experience with them and how do they compare as far as taking up room in comparison to stock manifolds?
Thank you
Joe.
Old Jun 20, 2010 | 08:47 PM
mopardrt's Avatar
pshhhhhhhhhhh dont even get me started with headers we had to lift the motor out of the K frame drop the K frame down out of the bottom of the car pull the power steering pump out the battery and battery tray the Gear box all the suspension and brake booster and the steering column , just to fit headers onto my 1974 dodge dart 318 sooooooo Im not quite sure if you have more room or less on your dakota BUT, good freaking luck
Old Jun 20, 2010 | 09:27 PM
1966sportfury's Avatar
A.K.A Bob Dodge
dakotas came with 318,s and the 340 is the same dementions on the out side, they make block huggers for the 318,
Old Jun 21, 2010 | 02:37 AM
You may need to run a new collector pipe, but they should fit.
pipdog69
Mar 13, 2012 11:01 PM
68satellite
May 23, 2009 05:33 AM
Brent1960
May 17, 2009 04:25 PM
mahd
Apr 2, 2009 09:05 AM
ProEmaster
Mar 1, 2007 12:19 PM
