BRAKES went out! Help!
Old 07-29-2010 | 06:16 PM
samuelcosmo76's Avatar
So I was driving all over in my dart today, and all of a sudden, my brake pedal hits the floor. I was able to stop, get out....no leaks or anything. Get back in the car, the brakes pumped right up and felt like normal brakes all the way back to my house.
I did the back brakes last week, and a return spring looked questionable, but I took off the drum when I got home today and it wasn't broken. Anything else I should look for? No leaks in the lines or cylinders at all.
Thanks guys!
Old 07-29-2010 | 06:28 PM
1966sportfury's Avatar
A.K.A Bob Dodge
sounds like faulty master cylinder, when they went to the floor could you push hard on the pedal and the tires lock up?
Old 07-29-2010 | 07:05 PM
Nope. They went to the floor and the car was still rolling. When I stopped it I pumped the pedal and they came back up.
Old 07-30-2010 | 06:35 PM
blue 68 gts's Avatar
Did you put new wheel cylinders in?
If yes, did you bleed them?
I say bleed the system and go from there.
Old 07-31-2010 | 01:31 PM
I didn't put new wheel cylinders in. And there are no leaks. I got a rebuilt master cylinder for $20 and put it in, but now the brakes don't pump up at all, and barely stop the car.
I did bleed the master before i put it in. What should I do?
Old 07-31-2010 | 02:04 PM
Something I forgot to mention...When I bled the new MC, when I poured fluid in it instantly started dripping out of one of the holes. Is that supposed to happen? Is it possible i got a bad one?
Old 08-01-2010 | 09:15 PM
A.K.A Bob Dodge
bad seal,
Old 08-01-2010 | 11:15 PM
so in other words i got a bad rebuilt cylinder yeah?
Old 08-02-2010 | 08:10 AM
Yea pretty much, Put the old one back on and re-try unless there was something bad with the old one.
Old 08-02-2010 | 11:43 AM
yeah the old one was shot....just barely got home that day haha.
i ordered a new one...my parts guy warned me about the rebuilt ones, but i was trying to save some . is that a common problem?
Old 08-02-2010 | 04:57 PM
A.K.A Bob Dodge
i never bought a rebuilt one, i usually rebuild them my self, theres nothing hard about it, just the kit and a quick hone job on the master cyl,
chlngr1970
05-30-2012 02:18 AM
64polara
Non-Mopar Tech Questions
10-06-2010 05:08 PM
Crazy4Carz.Com
06-17-2010 10:18 PM
koondawg_74 roadrunner
09-16-2009 01:44 PM
rampage_82
12-07-2007 08:22 AM
Quick Reply: BRAKES went out! Help!
