can i run a solid cam with hydraulic lifters?
I brought this cam for my supercharged 360 magnum engine. I was going to run solid lifters with it but now i would like to save a few dollars and run my existing hydraulic lifters. Can i use hydraulic lifters on a solid cam. The only difference i can see between a hydraulic cam and a solid cam is the lobe width or is it more complicated than that?
cheers Maca
cheers Maca
I measured the 2 cams up and it looks like it would work fine but the general coconscious seems to be not a good idea so I will go solid lifters. Comp cams didn't give me a reason but said (It's not typically recommended)
I have not run a solid cam before so what preload do I run on them?
Zero lash or small preload?
cheers
cheers
That valve adjustment shown for solid lifters is the gap between valve stem and rocker tip.
For hydraulic the pushrod should go into the lifter and depress the plunger with no slack or gap in the valve train.
I thought you were going to be using hydraulic roller lifters on a solid cam.
Yes at this stage just throwing the idea out there to see if anyone has done it.
On my Hydraulic cams I usually run .060 but I have never run a solid before so I would just set as per the card.
Cheers
PS I have really noisy lifters on my 360 magnum that one seem to pump up all the time. Very rattly. I recently replaced all of them and the new ones seem to be the same. Don't seem to pump up all the time. Anyone else had this problem with magnum lifters? I question their quality as they are only about $110 for a full set. My oil pressure is fine too.
Cheers
maca
Apr 17, 2015 08:02 PM
maca
Feb 21, 2015 05:40 PM
maca
Jul 17, 2014 03:13 PM
