Can't break out of the 15's on the track!!!
Old May 4, 2009 | 05:27 PM
Red Devil's Avatar
Little Demon
yeah man you can't keep beating on that car like that, it will only get worse. I don't want to sound like a jerk either but that is a damn valuable car and you really should not run it like that until you solve whatever problem it has. take hypermite's advice and look the motor over REAL good
Old May 4, 2009 | 05:53 PM
X3 on what they said...........
Pull the plugs, number them, take pics and post them up.
Old May 4, 2009 | 08:03 PM
Crazy4Carz.Com's Avatar
This is the calculation to figure HP based on MPH. Your Velocity (89 MPH) divided by 234 equals .38 and that figure cubed equals 0.06
Your vehicle weight (3836) multiplied by 0.06 equals 230 horsepower.
That is correct. 230 horsepower! None of you may like it but that is where that car is. Unless he is lifting well before the traps, Miles per hour doesn't lie.
Regardless of wheel spin poor launch etc, MPH is fairly consistant.
There may not be much wrong with the car. Many of you believe these cars are rocket ships. On the contrary these cars were fast in the day but by todays standards these old muscle cars are not as fast as we like to think. The old horsepower ratings were SAE Gross, and the new stuff is no longer measured that way. The actual BHP of the older engines is actually much much lower than the advertised ratings.
Do some tuning, freshen up everything, remove some weight (spare tire, Jack, golf clubs, Etc) and go try it again. But the best you shoud hope for is a mid to high 14.
Good luck.
PS SEE THOSE MATH CLASSES AND PHYSICS CLASS DID COME IN HANDY AFTER ALL.
Old May 5, 2009 | 01:38 AM
I know what you are saying Steve, it just seems like those are small block numbers. I would have thought that He would be able to hit 14 at least.
Old May 5, 2009 | 06:22 AM
I think that I have said it before. You should go to a dyno shop and pay to do a couple of pulls, then have them make the adjustments needed to get it to run really well. Thats what I plan on doing once i get my valiant back on the road.
Old May 5, 2009 | 08:38 AM
Excellent advice. I am doing the same with Project Dart. I did some track tuning but the Dyno is so much faster and accurate.
Old May 5, 2009 | 01:46 PM
i also hope that you are using an oil with zinc in it
Old May 5, 2009 | 03:07 PM
Red Devil's Avatar
Little Demon
yeah if you ain't using an oil with zinc you might be developing some serious issues with that motor every time you drive it
Old May 5, 2009 | 05:58 PM
Just use synthetic. The Zinc thing is blown way out. Everyone here should be using synthetic oil anyway.
Old May 5, 2009 | 06:13 PM
Sorry Stickshifted you are comparing apples and oranges. The horsepower rating you are using for the 440 is totally different than the late model crate motor. Not the same at all.
You said his motor made 270 hp and he ran mid 14's
this 440 makes 230 hp and runs 15's
Sorry you don't have to agree with me, and you don't have to like it but Physics is Physics and the numbers don't lie. The mathematical formula works every time. You car argue and fuss, and not believe me at all, it doesn't matter, this car in "stock" trim will never run better than a mid to high 14.
BUT WAIT!!! the "F.A.S.T" serries race cars that are running factory looking cars with all original parts on the outside are running much faster numbers than these. On stock tires! Right! those are NOT stock cars. These cars have metal cut out everywhere they can and are lightened up every way possible. you can't compare a stock car to one of these.
The old 390 factory hp rating was flawed and they all knew it. these numbers were in place to sell cars. the later rating system rates in SAE net numbers that are acurate.
Go back and look at what times these cars turned when new by the testing magazines of the day. They were not much better than these numbers and that was on cars prepared to perform for the magazines, and driven by professionals.
Enjoy your old muscle car, but dont try to compare it to todays technology, it can't hold up. Enjoy it for what it is.
Old May 7, 2009 | 01:59 AM
HP doesn't really matter, It's the torque that you need to push you down the track...... right? That and how well you can get the tires to hook up?
Old May 7, 2009 | 04:10 AM
Torque = ET
HP = MPH
Old May 7, 2009 | 05:17 AM
Torque = ET
HP = miles per hour
Gotcha!
Old May 8, 2009 | 03:25 AM
You are not pissing anyone off.
The apples/oranges thing is SAE gross and SAE net HP ratings. The Chevy motor and the big block 440 are rated differently and ultimately have real world similar HP output.
The math formula (not mine) shows exact HP. Unless he is lifting before the end of the track this is the EXACT hp produced. Yes, regardless moderate of wheel spin etc. Go back and look at the ET the magazines were getting in the 60's. Sorry but a mid to high 14 is the best to hope for.
Old May 8, 2009 | 09:13 AM
  #24
maybe its the connection between the seat and the sterring wheel?
(j/k MrMopowered)
Old May 8, 2009 | 06:48 PM
  #26
Originally Posted by stickshifted
hmmm. well regardless, i think we can agree his engine has some issues. we can only hope its simply tuning, but he might have messed something up running it like that.
and if the best time he can hope for is a mere 14.5, then he should be running at least 14.7's then he in no way should be running a 15.659. his reaction time cant be that bad
wonder how much better he'd do with a A-833 instead of that 727.....
Reaction time has nothing to do with ET or miles per hour. The clock starts when you break the beam, not when the light goes green. (popular misconception)
Old May 13, 2009 | 02:39 AM
  #28
Polaradude's Avatar
You can get this crazy gas in a blue bottle, it works like a hot dam. It's got N0s printed on it...new old stock I guess..lol. Say bye bye to 15's
Old May 13, 2009 | 05:37 AM
  #29
craveman's Avatar
Senior Member
just thought id put my input in too. a car that old also wont have its original hp even if it is low miles. 5th aves were rated at 140 hp and 260lb ft of torque with the 5.2l. mine when i got it had 114 and 232lb ft. with only 80000 on it. now its currently at 186hp and 292lb ft with headers, a performance ignition, dual exhaust, and a 4bbl carb/intake. ive seen other ratings for a 318 that said it had 300 hp. the thing is it had the same size cam, carb, intake, pistons, and exhaust that my car had. just my 2 cents
Old May 13, 2009 | 05:40 AM
  #30
craveman's Avatar
Senior Member
also has ported and polished 302 heads
