Cant Get Valve retainers/clips When I Compress the Valve Spring
Old Sep 19, 2012 | 08:30 PM
74Runneer's Avatar
Exclamation Cant Get Valve retainers/clips When I Compress the Valve Spring
I just got my 302 casting heads and i cant seem to get the springs off, I compress the spring and the valve just goes down with it. I tried putting carb cleaner on it and tapping the valves with a rubber mallet and nothing seems to work. Am i doing something wrong? Also can i silica sandblast all the parts (valves rockers springs and head itself) without damaging them? or how should i clean them? Thanks
Old Sep 19, 2012 | 10:02 PM
You could media blast them with something like walnut shells. DO NOT sand blast them...
Are you holding the valve closed ?
Old Sep 20, 2012 | 08:23 AM
70redbee's Avatar
You need a valve spring compressor tool that holds the valve closed while you compress the springs. You can buy one at Sears or any online tool dealer or parts supplier.
Old Sep 20, 2012 | 08:43 AM
You need the large "U" shape valve spring compressor the holds the valve closed. Like before mentioned I bought one at Sears.
Old Sep 20, 2012 | 08:47 AM
This is a common problem. The locks are wedged in the retainers is all. Pack some rags under the valves and lay the head on a wood bench. Take a piece of tube or socket and extension which will fit on the retainer and give them a sharp but not heavy blow with a hammer.
If the heads are rusted from exposure, you might first try leaving for a few days, and apply a little penetrating oil every day.
Old Sep 25, 2012 | 12:15 PM
Gorts 5th's Avatar
Smile
yep that works for me
Old Oct 17, 2015 | 10:07 AM
ritroutt's Avatar
no sand
You need to block the valve to keep it from moving. a regular c style valve spring compressor will solve your problem.
I recommend you find a shop that knows how to really clean parts. It's worth the money. No blasting.
Old Oct 17, 2015 | 10:32 AM
Magoo's Avatar
Smile OLD POST
-- WELCOME -- You need to look at the date of posting. This series goes back to 2012. -- Not a problem. -- Enjoy it here.
robertherr
Apr 5, 2012 04:37 PM
SPICOLIE203
Nov 23, 2011 05:59 PM
chezhed
Aug 8, 2011 07:09 PM
xjonathanx
Jan 30, 2010 09:36 AM
v8only
Jun 5, 2009 04:27 PM
