Charging Problem
Old Apr 6, 2009 | 08:15 PM
  #31
SixtySevenDodge's Avatar
I did that first.
Old Apr 8, 2009 | 03:43 AM
  #33
theomahamoparguy's Avatar
[quote=SixtySevenDodge;16810]Would an electronic regulator just bolt right in place of the mechanical one using the same connections and everything? And the alternator isnt listed as a dual field and it doesnt have the second prong, just a screw where the second prong would be. Also I am trying to trem...
Well, the old regulator has one hot and one alt/sensor {that's only what i call em. dont know actual name} the green wire is the sensor wire, it goes to the field on the alt. of course the blue wire is hot going to the other side of your regulator. You've got the same wires on a newer elec. voltage regulator. The only difference is the extra wire going to the other field on the newer style alt. It is a hot wire[key on source]. It sounds like you havr the newer style alt. Make double sure its a new style alt by comparing it with another one.
The electronic regulator requires the dual field alt and vice versa.
Old Apr 9, 2009 | 08:15 PM
  #35
Ive cracked the mystery. It was a mix between high resistance in the bulkhead connector/ammeter and a bad regulator. I bought a new regulator today and stuck it on there. Im still trying to adjust the darn thing so its not cranking out 11v or 17v which is like a hair away from each other. Its so sensitive. Definitely putting money towards dual field alternator and electronic reg. Right now I have a fused 10 gauge wire running from the ign relay to the batt post on the alternator. I eliminated the fused link wire from the relay to the bulkhead, which also eliminated the ammeter. Eventually when I get a voltmeter Ill hook it back up but for now its good. When I first put the new regulator on the car would blow 30amp and even 40 amp fuses when accelerating which killed the entire car's electric lol. But it's getting close to midrange. I dont really trust it completely yet at night because of what Ive been through and I have to get used to it again. Im still afraid of it dying or blowing fuses even though it should be fine now. Headlights are nicely lit and they dont flicker like crazy. Every once in a while it will flicker just for a split second and its very miniscule so its probably a normal thing.
mooregw
Nov 25, 2011 06:51 PM
74Duster
Dec 17, 2009 12:13 AM
moparmaniac
Apr 4, 2009 12:25 PM
MoparMan
Jan 16, 2008 04:20 PM
nicolette
Dec 19, 2007 12:13 PM
