D60/4:10 locker on the street??
Old Jun 7, 2009 | 10:27 PM
blue 68 gts's Avatar
Well.... with a 4:10 locker, you won't be getting very far, very fast. you try going 60 mph, it'll be revving very high in 3rd gear...
3:73's are a decent set for cruising... but I'd go to 3:54's. But thats just my opinion...
-nick
Old Jun 8, 2009 | 01:53 AM
4.10 gears and a locker will sell on a local 4x4 forum easy (depending on the locker that you have). You may even be able to trade for 3.73 or 3.55 gears and a sure grip.
Drive it when you get it and see how you like it. There are different types of lockers out there and they all act different. Sure grip (aka posi) is easier on the vehicle and you for cruising though.
Old Jun 8, 2009 | 08:20 AM
1 Bad Mirada's Avatar
Administrator
i street drove the mirada with a 4.56 and a locker...i also drove it on the street with a tight suregrip and a 4.88...THAT was too much. this is all with a 727.
i dont think that the mirada is that bad with the locker. it can be a little tough maneuvering around tight parking lots, but thats with a 456 and 4000 stall. when im moving, i dont notice it very much. the hardest thing is when im at the track, and i have to make a tight turn to get onto the trailer...
btw, nice sig!
Old Jun 8, 2009 | 08:42 AM
Administrator
im afraid ive mis-spoken a bit. i have a 4.56 with a spool, not a locker rear. the results should be similar, but the locker may have more give..im not sure.
i dont think that there is much use for the locker or spool unless you race a ton and are breaking rearends. i think that the spool reduces some of the drivetrain weight, but other than that my suregrip got just as good of traction.
Old Jun 8, 2009 | 09:01 AM
A locker is designed to disengage when let off the gas and turning to allow the tires to turn freely. If you get on the gas while turning with a locker, You will either hear it "ratchet" or the tires will give and chirp.
Old Jun 8, 2009 | 09:29 AM
Administrator
gotcha..that was what i thought, but i wasnt 100% sure.
so, to elaborate on the question, i run a spool and dont have many issues.
Old Jun 8, 2009 | 10:51 AM
Administrator
duster, you didnt have to change your avatar just because i had it!
although, that new one is pretty sweet too.
Old Jun 8, 2009 | 04:04 PM
when you get it, dont forget pics
Old Jun 9, 2009 | 06:36 AM
Administrator
how heavily built is your 440?
Old Jun 9, 2009 | 10:21 AM
Administrator
well, if nothing else, it appears to have been painted...and if someone pulled it to paint, there is a chance that some work was done to it internally.
Old Jun 9, 2009 | 02:37 PM
hmm, cant really tell
Old Jun 9, 2009 | 09:33 PM
deadkelly's Avatar
are we talking mini or full spool or locker .
i have a Detroit locker in my 8 3/4 its fine for street driving . mini spool or full spool or welded locker is another story . 4.11:1 is a bit much for hwy driving , but around town on weekends to the track & back no worries . if you don't drive into shopping center car parks I'd keep it .
Old Jun 24, 2010 | 03:23 PM
mopartony's Avatar
Junior Member
Hey Chris.....do you still have that 71 440 duster???
Old Jun 24, 2010 | 07:15 PM
Buffalojoe426's Avatar
I have a limited slip differential in my scout that dosen't seem to limit that much slip any more. When I am in the pasture and step on it just one tire spins, and both are slick. Is there any way to sure it up? maybe I put the wrong type of gear oil in the rear end? any ideas? sorry to high jack the thread.
Old Jun 25, 2010 | 02:51 AM
D44 rear axle with a Tru Trac?
All limited slips need an aditive to help "activate" them.
Old Jun 25, 2010 | 05:52 PM
67gtxclone's Avatar
I recently changed out my 3:91 suregrip (no locker) for a 3:55 suregrip for driveability on the freeway. I don't have a functioning tach, but with 3:91s, I can tell you that at freeway speed, I was looking for a 5th gear. I am guessing I was doing 3600rpm in 4th gear at around 70 miles per hour.
Old Jun 25, 2010 | 10:15 PM
  #24
1966sportfury's Avatar
A.K.A Bob Dodge
it has a aftermarket intake thats for sure! but can never tell, ive seen "stock lookin" engines that had been built hard core, just keep it lookin plain for a stealth look
Old Jun 26, 2010 | 05:24 AM
  #25
That's what I figured, would it have hurt anything having that regular gear oil in the case?
Old Jun 26, 2010 | 07:19 PM
  #26
Not at all, your limited slip just won't work as well and may burn up the clutches a little faster than normal at which time will act like an open carrier.
Old Jun 27, 2010 | 02:35 PM
  #27
tang72's Avatar
I had some similar questions about dropping a LSD with 4.11s in my charger with a 440/ 727 but im pretty sure im going to drop it in anyways... i usually just cruse around town with it and im hoping those steep gears will wake that big car up off the line. 4.11s are just a little scary with 3 gears and all...
Old Jun 28, 2010 | 03:02 AM
  #28
Those 4.11 gears will really make that car get up and go.
Old Jun 29, 2010 | 12:50 AM
  #29
tang72's Avatar
Yea i hope they do but first is getting my paint & body finished.
Old Jul 12, 2013 | 05:02 PM
  #30
GotScout's Avatar
D-60 / 4.10's
AND A DETROIT LOCKER! :-) on 33's
That is all hiding under that fancy green cover.
(73 Scout... with a few mods! and 318 powered so I can hang with the cool kids too!)
Aside... the gears are great offroad and starting up quick... but for long distance, top speed and highway (and GAS...) : THEY SUCK!!!!!
For general... I think 3.54 are ideal.
