daughters car wont start
Old Jun 20, 2011 | 01:30 AM
dodgenut7's Avatar
i need help my daughters car is a 1995 pontiac bonneville with a 3.8 motor her husband started it go pick her up at work and it was fine haif way there at a light it lost some rpm's did not stall he got to where she works and was waiting for her to come out with it running idling alittle slower daughter said it sounded like it making a putting noise he gave it gas and it made a loud screeching noise like stepping on a cat my daughter said it sounded like it came from the rear of the car not the motor then stalled now it still turns over but wont start iam leaning towards the fuel pressure regulator because she says that when she turns the key she can hear the pump kicking on plus i cant believe that the injectors would go at once she says it sounds like its out of gas but she has a full tank any ideas of info or thoughts would be great
Old Jun 20, 2011 | 06:11 AM
fivepoint's Avatar
I don't know where the load noise would have come from but, it sounds like fuel pump to me.
Old Jun 20, 2011 | 06:25 AM
fivepoint's Avatar
I know I just wrote I suspected fuel pump. I had a Lumina that did the same thing. Take a fuel line off and check the pressure. Hope that noise she heard wasn't the timing belt
Old Jun 21, 2011 | 07:06 PM
scotts74birds's Avatar
Please, please, please troubleshoot the problem before making the fuel pump companies any richer!!! Rent a fuel pressure test kit from autozone. Things like cam and crank position sensors will stop the injectors from firing!
Old Jun 21, 2011 | 08:02 PM
Silverick's Avatar
My thought also.
Old Jun 21, 2011 | 08:07 PM
sgnrulz's Avatar
Even though GM is notorious for dying fuel pumps this is an excellent suggestion. Especially cause I've personally encountered a 3.8 crank sensor going out the engine stopping dead and it caused the belt to chirp.
Old Jun 21, 2011 | 09:06 PM
dodgenut7's Avatar
first off i would like to say thanks for all the advice it turns out that it was the ignition module i am not sure what the noise was but the car runs great now
Old Jun 24, 2011 | 06:51 PM
I love happy endings! [Sniff!]
bengibbard13@gmail.com
Aug 10, 2010 05:41 PM
6865coronet
Aug 11, 2009 09:55 PM
shelbydz
May 9, 2009 03:10 AM
duster74
Feb 11, 2009 07:43 PM
dodgeaspenrookie
Jul 18, 2008 07:28 PM
