distributor problems
Old Nov 9, 2012 | 04:36 PM
jimmyb's Avatar
can I use a big block distributor in a small block 318. is there an extension for the shaft. I just bought a mallory dual point at a swap meet and found out its for a big block
Old Nov 9, 2012 | 04:47 PM
Not Possible !
Old Nov 9, 2012 | 06:35 PM
moe7404's Avatar
electric dis
chrysler makes a hole electronic system for small and big block engines, at least they did. it is much better than point dist. its a copy of the stock system they made in 1973. ill try to find the number. ill get back to you.
Old Nov 9, 2012 | 07:11 PM
moe7404's Avatar
i found this
i found this. summit has them but so do other people. summit allso has race models that are billet, they are very expensive, you do NOT need that one. you need mopar performance p3690426. for, 273, 318, 340, 360 kit has all the parts you need. $225.95. the people that have the older cars think that adding the electronic kit does NOT lower the value of a mopar. hint get two extra ballast resistors. put them in the glove box, the first time the weather gets cold or hot, and it doesnt start , swap the resistor first. it is the best deal around. just think no more setting dwell angle.
Old Nov 9, 2012 | 08:00 PM
Chryco Psycho's Avatar
aside from the length problem the dist rotates the opposite direction so no advance !!
Try Mancini racing , they have kits
Old Nov 9, 2012 | 08:04 PM
Mancini also has kits to run a RB block distributor in a 400 or 383.
Old Nov 10, 2012 | 04:29 AM
Mr.4spd's Avatar
Sounds like a good candidate for Craigslist.
Old Nov 11, 2012 | 07:22 AM
Gorts 5th's Avatar
Smile
yea a dual point is already a tuner and the electronic magnetic pickup is better,
i installed the Mallory ss distributor i wanted some thing with less separate parts with the proper Mallory coil i have also eliminated the ballast-resistor, also i love this simple clean combo.
Attached Thumbnails distributor problems-p1020288.jpg   distributor problems-p1020293.jpg   distributor problems-p1020302.jpg
xvodysseusvx
Jun 25, 2018 04:38 PM
hillbillyape
Nov 23, 2012 06:57 AM
JUS
Apr 16, 2008 03:55 AM
coupe3w
Mar 13, 2008 09:38 AM
Commando
Dec 13, 2007 11:15 AM
