dont know why my motor is missing under load
Old Mar 5, 2014 | 03:37 AM
maca's Avatar
Hey all
I have just finished building my Australian hemi 6 cylinder. It has hydraulic lifters and a fairly big cam. 10-5 comp, I am running a 4 barrel manifold and carby.
What its seems to be doing is breaking down under load. It seems to break down almost like someone has pulled a lead off. When it gets to about 5000rpm it runs great briefly as the cam maxes out at around 6000.
I have tried different valve preloads. 2 electronic dizzys, 1 points dizzy, 3 different coils and 3 different carbys, 3 sets of plugs and leads but still no luck. I have tried 95 and 98 octane fuel. I have a constant 13-9v at the coil and 14-4 at the battery. I have tried running a wire from the battery to the coil instead of running it off my ignition but it didn't help.
On the weekend I put it on a local dyno and they could not find out why it is doing it. The AFR was fine but as the motor got hotter after a dozen runs it got better and wasn't missing at all. When I pulled it off to drive it home it was terrible and missing again. Its driving me up the wall.
Any ideas?
cheers Greg
Old Mar 5, 2014 | 06:45 AM
So Ignition has been ruled out as being the problem.....
What do the plug readings look like....
On another note... With the heat or higher temp being a factor.....
Sounds like the motor might be heat sensitive. combustion chamber might be running to cool causing a rich condition?
Old Mar 5, 2014 | 10:44 AM
Lean, rich, plug readings. Any dyno operator worth their salt should have been able to shed light on this
Is it using coolant?
If this was lower RPM I would have suggested carb icing.
Valve float except you said it "ran good briefly" at high RPM
I sure donooo.............
Old Mar 5, 2014 | 12:01 PM
Have you done a compression test ? Or a leak down test ? Check the valve spring pressure..Maybe a flat cam
Old Mar 5, 2014 | 01:43 PM
maca's Avatar
comp test was fine. all pretty close.
Plugs look ok as on the dyno the AFR was fine.
The carbys I tried were all off other running motors so I don't think its carb. Maybe manifold if anything.
Once it got pretty hot it ran better on the dyno but they only ran it flat out. not cruising speed.
I have tried so many things I am out of ideas.
Old Mar 5, 2014 | 02:15 PM
Are you sure the engine is not (fat Rich) on the inner cylinders and lean on the outter cylinders....
AFR.... Give us the reading's On. The Low range, Mid Range, High Range,
Old Mar 5, 2014 | 03:00 PM
Drag Pak's Avatar
Maca
Can you tell us what preload you are/have been using for your valve adjustment?
Have you tried "0" preload?(just enough to get the pushrods rotating)
Have you tried a hot set on the valve tappets?
Old Mar 5, 2014 | 03:21 PM
maca's Avatar
I will try to get a pic of the dyno graph and post it.
The dyno is not a great example as it ran better on there. AFRs were around 12-5. It got lean down low for a brief second but then the secondaries opened and it went back to 12-5 again.
I have tried .040 and heavier but set at cold.
I don't think its preload as it ran well on the dyno after a while.
These engines are very common here in Australia and preload seems to be fine between .020 and .060 and even more in some cases.
Because I was thinking its electrical when it started playing up in the beginning on the dyno I disconnected the alternator and it instantly ran 100% perfect. So I thought I had found the problem. When I connected it back up it still ran fine. So as soon as it started playing up on the way home I disconnected the alternator again but this time it still ran bad so it must have been a coincidence.
Old Mar 5, 2014 | 05:43 PM
bigblock's Avatar
Sounds like the lifters are pumping up.As the oil gets hotter/thinner it sort of corrects itself.
Old Mar 5, 2014 | 07:23 PM
Sure its not a bad ground?
Old Mar 6, 2014 | 03:54 AM
maca's Avatar
I did think that too so i checked the ground and on one of my drives I hooked a jumper cable from the battery- to the engine but didn't help.
Old Mar 6, 2014 | 08:42 AM
How Large is the Exhaust header and exhaust pipe?
I'm thinking that this engine is just on the lean side..
Old Mar 7, 2014 | 07:40 PM
maca's Avatar
The exhaust system is a single 2-5 which is a very common size for these motors here.
I ran it today with points but no luck again
So I started looking again for other things. I put it up on the hoist and noticed oil running down the side of the block under the intake. I removed the starter motor to get a better look. It looks like it may be coming from the head gasket area but I cant really tell. I think I will have to pull the exhaust & intake off to find out. There is a tiny bit of oil on the very back corner of the rocker cover but the oil on the block is further forward which I wouldn't have thought the oil would travel forward and it only looks damp on top, not that much oil. Here is a video, Maybe I shoul comp test it again or do any other tests before I pull the intake/exhaust off?
http://www.youtube.com/watch?v=HroXl0-V ... e=youtu.be
Old Mar 8, 2014 | 08:57 AM
Just re-torq the head.... Clean it up and recheck it after a few miles....
I might do a Cyl. Leak down check and a compression test just for the record.
Run a Vid of the missing...
Old Mar 18, 2014 | 04:25 AM
maca's Avatar
My son took some go-pro video of it missing.
You can hear it best at the beginning
http://www.youtube.com/watch?v=o4rLN...ature=youtu.be
Old Mar 18, 2014 | 09:16 AM
I don't hear the miss....... I hear the exhaust reverb / reignites (??) but that's all I hear.
Old Mar 19, 2014 | 04:03 AM
maca's Avatar
It's hard to hear with my exhaust but have another listen. One of the videos is better than the other.
Old Mar 19, 2014 | 08:29 AM
Pull The plugs and let's have a look .... (Photo)
Have you tried the NGK Spark plugs?
Old Mar 20, 2014 | 05:20 AM
maca's Avatar
I will get a pic up asap. Number 6 is the richest.
Yes running the Ngk plugs.
Old Mar 20, 2014 | 10:11 AM
Over advanced ign
Old Mar 20, 2014 | 01:24 PM
pro-tech's Avatar
Start backing the timing off 4* at a time seems to far advanced...Bill
Old Mar 22, 2014 | 11:42 PM
maca's Avatar
I have played with timing quite a bit. I have a mopar mechanic coming next weekend for a look so hope he can find the issue. Here is a pic of the plugs
cheers
Old Mar 22, 2014 | 11:47 PM
maca's Avatar
also this seems unusual to me. See the burn marks on the poles in the dizzy cap. This cap has only had a few hours running since new.
Old Mar 23, 2014 | 02:53 AM
  #24
the one plug is lean others are rich Are you adding any gas additives ? Try a different distributor, cap and rotor
Old Mar 23, 2014 | 08:55 AM
  #25
Ok.... Here is where I am at with this.....
Those spark plugs BP5ES or 7333 (Gap of .051) are not the rite plugs, at least I dont think.
Use a NGK GR4 or 2635 NGK and gap to a .035
Have your Dist Recurved if you can. It is pulling way to much advance.....
If not then, try this.
Start off with about 4* of timing and lets see if that helps.
Also The carb is way to rich... But leave it for now, till we get the other stuff rite, Maybe it will only take a little fine tuning? If not it looks to me like its about 6 jet sizes too big.
Your #4 Cylinder is not firing at all.
Check: Spark Plug... Plug Wire.... Valve adjustment.... Check for a Vacuum leak. Make sure it is sealed.
Just My 2 Cents....
Cap looks ok... Could be from the wide gap on the plugs or weak wires.
h340
24
Dec 18, 2014 09:19 AM
ottosen@chorus.net
Aug 4, 2011 05:24 AM
Moss
Jul 5, 2011 05:26 PM
68camperspecial
Apr 14, 2009 05:28 AM
