electrical
Old Jan 25, 2009 | 01:24 PM
sgp7679's Avatar
Question electrical
What are some common electrical parts the go out and would cause a car to stall and not restart. I have changed the ballast resistor, electronic ignition,coil,wires and plugs and still no start.
Old Jan 25, 2009 | 03:20 PM
Crazy4Carz.Com's Avatar
Bypass the ignition system. run a wire from the battery to the positive side of the coil. It should run then work backwards from there.
Old Jan 25, 2009 | 07:06 PM
Polaradude's Avatar
I would agree with 66, check for bad grounds and do what Crazy says.
Old Jan 25, 2009 | 08:37 PM
challenger's Avatar
where are you located at sgp
bpatterson
Feb 4, 2009 08:41 PM
64fury
Jun 17, 2008 02:27 AM
64fury
Mar 9, 2008 02:02 PM
TCPMeta
Mar 28, 2007 04:27 AM
