Electrical gremlin?
Old Jun 11, 2008 | 09:24 PM
64fury's Avatar
Electrical gremlin?
I'm having a hard time figuring out why, my horn, clock, water temp and gas gauge don't work. I've checked every thing I can think of, I even have a second instrument cluster, and have re-wired all the grounds behind the dash and the fuse box.
Looking at the wiring diagrams the effected items don't share anything in common.
And on a semi related mote does anyone know the Ohm range for the fuel tank sending unit? How many ohms full how many empty?
Car is a 64 Sport fury!
Thanks in advance!
Old Jun 12, 2008 | 04:43 PM
64fury's Avatar
Originally Posted by gilesie
I would think that the temp & gas gauges would share a voltage regulator
I know my horn isnt working due to corrosion in the plug in the bulkhead/firewall
easiest way is to get a multimeter and check grounds & voltage
I've tried 3 different and new regulators, re grounded all the grounds, tried a second set of gauges, and re-wired the fuse box, in theory they all should be working, but arn't!
Old Jun 15, 2008 | 09:36 AM
64fury's Avatar
Have you checked the voltage at the guages?
Yeah! I'm getting Ohms at the sending unit and the gauge, and voltage at the gauges. I have two instrument clusters and have tried both, along with 3 new voltage regulators, I've even ran new wiring from the sending units direct to the gauges so there are no shorts or breaks in the line.
Since I want to drive this car asap I've ordered a set of after-market gauges, Electric water temp, Electric oil pressure, and fuel level, and will mount them in a pod next to the shifter so I can drive it daily while still trying to figure out the original gauges!
On what may be a related subject, I noticed yesterday that when the ignition is on, but the car not running, the left turn signal is dimly lit, anyone have an idea what this is about?
thanks
Mike
Old Jun 16, 2008 | 05:52 PM
64fury's Avatar
I brought the car back in October, everything was working then, i only briefly drove it (like a day) before the snow came and i put it away for the winter, i never really got a chance for a good shake down before I had to park it!
With the dimly lit signal light being a possible ground fault, I'll have to go looking behind the dash and elsewhere, I'll bet dollars to doughnuts this is related to the gauge/horn/clock issue!
70newport
Jun 21, 2014 07:49 PM
70newport
Aug 18, 2012 08:25 AM
Mar 31, 2012 07:15 PM
samuelcosmo76
Jun 4, 2010 03:23 AM
johnthegoalie
Apr 21, 2010 09:02 PM
