Wiring Gremlin :-[
Old May 28, 2010 | 07:50 PM
samuelcosmo76's Avatar
Wiring Gremlin :-[
A few days ago my hazards and right turn signal stopped working, replaced the flasher under the dash, and they started working fine. Shortly after, they stopped working again. Now I'm also noticing that my fender turn lights are always on, even when my lights aren't on.
Waddaya think guys?
Old May 29, 2010 | 06:53 AM
sweeperking's Avatar
It sounds like you may have a short in your turn signal switch. Check your brake lights and horn do they work ok? Does the left side work ok? When you say fender lights are always on, both sides? what about the rear?
Old May 29, 2010 | 07:01 AM
The brake lights work ok, and the left side blinker works ok. Also, only the front right fender light stays on, so I don't think its a short in the turn switch. This is a real pain in the neck because it will work fine one minute, and the next all this stuff starts to happen.
I know this is hard to diagnose over the internet, but i appreciate any ideas! :-)
Old Jun 2, 2010 | 03:55 AM
dodgenut7's Avatar
could be faulty contacts in your switch i dont know just a thought
Old Jun 2, 2010 | 04:26 AM
Real hard to diagnose from here but my suggestion is to go to the front and rear turn signal composits and check each socket for corroision, check wires to the sockets for bad connections and check your grounds. If you havent done so already put a heavy duty flasher in it (552). When that fender light stays on it usually indicates a bulb out (a chrysler feature), make sure you also have the correct bulbs in it. I believe that they should be 1156 bulbs all around.
Old Jun 2, 2010 | 06:38 PM
thanks guys, I will check out those connections tomorrow. just a quick update....when i step on my brakes, the parking lights in the front come on. :-I
Old Jun 3, 2010 | 04:27 AM
Ok now I'm going back to maybe a bad turnsignal switch.
Old Jun 3, 2010 | 07:07 AM
really? i gotta check out a schematic....
Old Jun 3, 2010 | 09:43 AM
72RDRNR's Avatar
Have you checked all the grounds? Could be that it is making contact sometimes and then other times its not. Might be why they work then next day they don't.
Old Jun 3, 2010 | 05:51 PM
scotts74birds's Avatar
Kinda foggy, but does your car have the brake light that is flashed when stopped, or a separate turn signal?
Old Jun 3, 2010 | 05:54 PM
the blinker / brake light combo. i'm gonna trace the wire back from the brake switch and see what i see.
Old Jun 3, 2010 | 06:30 PM
So you are flashing the brake light? If so, it is in the turn signal switch. It overrides the brake light circuit. In that set-up the out-put of the brake pedal runs back up the column, and the brake signal is interrupted by the flasher system.
Old Jun 3, 2010 | 07:01 PM
thanks for the tip! do they still make those switches?
Old Jun 3, 2010 | 07:10 PM
Geezus, you just want everything, dont you?!!! HaHaa! What car are we dealing with?
Old Jun 3, 2010 | 07:14 PM
I'm high maintenance. What can I say? haha.
its a 76 dart.
Old Jun 3, 2010 | 07:20 PM
You had better be a girl...or a reallly cute guy. You have a Tilt column Sallie?
Old Jun 3, 2010 | 07:32 PM
I found this for you dear, http://www.rockauto.com/catalog/x,ca...%2B%2528G%2529
Old Jun 4, 2010 | 03:23 AM
You're a living doll.
I'm a guy. I think I'm cute though.
Thanks for the help broski!
70newport
Jun 21, 2014 07:49 PM
70newport
Aug 18, 2012 08:25 AM
Mar 31, 2012 07:15 PM
johnthegoalie
Apr 21, 2010 09:02 PM
64fury
Jun 17, 2008 02:27 AM
