Engine rpm’s
Old Jan 8, 2021 | 08:59 PM
Shano's Avatar
Engine rpm’s
Hi all.
just trying to get an idea as to whether or not my old style tacho is reading correctly? It has a screw on the back of it in which I believe is called a potentiometer? Or something like that so yes it can be adjusted. And yes it is switched onto the 8 setting. So this is in kilometres per hour as I’m in Australia. My diff ratio is 2.92. Trans is a 727 Engine is a mild 318. Rear tyres are a 235/60/15. So at 100 kmph my tacho is reading 2,600 rpm.
can anyone verify if this sounds correct please?
tanku.
edit. Mr google tells me 100kmph is 62.1MPH.
Old Jan 8, 2021 | 11:18 PM
Id say it's close but if you have a smartphone you can download an app for a speedometer in your phone. It's GPS and very accurate then you can verify you speedometer.
Old Jan 8, 2021 | 11:22 PM
Shano's Avatar
Hello mate. I do in fact have an speedo app in which I installed on my phone when my 15 inch wheels went on as I wanted to see how much difference there was going 14 to 15! To my surprise my speedo is fairly accurate so I know that is at least okay.
Old Jan 9, 2021 | 08:46 AM
Like I've said it's been awhile since I've used a gear that high but but it sounds about right.
Just what are you trying to determine, gear ratio or transmission slip.
Old Jan 9, 2021 | 10:49 AM
2500 seems high for that rear end gear ratio, in my opinion. like, big time.
Old Jan 9, 2021 | 02:46 PM
Shano's Avatar
Hi folks. I also am still curious but I managed to borrow a friends digital timing light/tacho yesterday and while in the shed the revs pretty well matched what his digital tacho was reading. Whether or not it’s different while driving I don’t know. I tried it through all rev ranges. The only real difference was at idle! His digital tacho was reading 780rpm and mine was more like 650rpm but I can live with that. It was the higher rev range I was interested in.
so perhaps it may be correct?? In the next few weeks I’m booking it in for a dyno tune as my carby and possibly the new distributor are not set up properly so you would think that his equipment would be accurate?
Old Jan 10, 2021 | 01:57 PM
Shano's Avatar
trying to determine if tacho is reading correctly. That is all.
Jun 9, 2018 07:28 AM
PowerRam318
Nov 2, 2016 05:08 PM
Terpodion
Jun 30, 2013 01:08 PM
Dart562
Dec 26, 2012 01:15 AM
ibstewrat
Sep 30, 2011 10:40 PM
