engine swap help ..dodge 318 to amc 360
Old Nov 23, 2008 | 02:42 AM
You can not bolt in an AMC 360 in place of your mopar 318. I explained it in the other post, they do not have the same bellhousing bolt pattern.
Yes Mopar (Chysler) bought out AMC back in the mid to late 70s (if i remember, may have been the 80's) but they did not do much to the FSJ production line. When Chysler took over making the FSJ, they left it alone as AMC did a pretty good job of building them, minus an oil presure problem and some wiring here and there. But Chrysler left the AMC 360s a lone and kelt making them all the way up til 1990 when the last FSJ rolled off the line.
If someone told you that the 82 AMC 360 would bolt in, bring the motor back to that person, unless you have a FSJ, a wrangler that needs a 360, or an AMC car that needs that motor.
paratrooper27th
May 11, 2023 01:55 PM
Fwmoraes
Dec 5, 2019 04:45 PM
SfloreS
Jun 21, 2010 12:08 PM
Josh
Nov 23, 2009 04:43 PM
mlithgow
Nov 26, 2008 02:15 AM
