Fuel regulator question
Old Jun 23, 2023 | 04:09 PM
JPR56's Avatar
Hey everyone got a question. I have a 1968 383 w/slight cam. Running with an Edelbrock 450. I just put a Temsone fuel regulator it goes up to 5 1/2. So I started at 2 and worked my way up to 5 1/2 and still won’t idle. What
am I doing wrong.
Thanks Again ……
Old Jun 23, 2023 | 04:44 PM
Kuvasz101's Avatar
Maybe I'm missing some part of the question. The fuel regulator? Why on a carburetor car? Are you running a high pressure/volume electric fuel pump? If so 5 1/2 lbs is sufficient for a decent idle. I think your idle problem isn't caused by pressure. Is the carb flooding while running or creating black smoke out the exhaust? Even with a slight cam they can be angry to idle. Best total advance (special timing light) is around 34 degrees + or- 2 degrees at 2000-2500 rpms.
Old Jun 23, 2023 | 05:25 PM
Ignition timing has to be correct before any carb changes are made. For a street cam you might need 10 to 15* initial timing at idle. Then you should have full mechanical timing in by 2100 to 2500 rpm, if you have stock cast iron heads total timing will be around 35*. The initial timing is critical for idle and off idle performance, especially for a nonstock camshaft. So increase the timing and see if it improves your idle. On a stock or aftermarket distributor you will need to shorten the amount of advance that’s in the distributor. You will need a curve from say 15* to 35* or twenty degrees of advance, your stock distributor may have 30* of advance built in.
Verify that the timing is correct first…
Old Jun 24, 2023 | 05:46 AM
Kuvasz101's Avatar
Sound baseline advice from iowan
Old Jun 24, 2023 | 06:43 AM
Old Jun 24, 2023 | 02:37 PM
JPR56's Avatar
You Gentlemen are Awesome. Did just you said runs like a champ.
thanks again people…..
Old Jun 25, 2023 | 04:44 AM
Kuvasz101's Avatar
It takes a village of Mopar owners to fine tune one. Glad it's running well.
Joe
Nov 4, 2018 05:36 AM
wizman
Member question and comments about MoparForums.com
Aug 7, 2016 07:37 AM
josehf34
Oct 28, 2014 12:25 PM
dodgenut7
May 1, 2010 06:36 AM
mfinkler
Nov 14, 2007 05:21 AM
