Gauges
Old Mar 15, 2009 | 09:18 AM
sgp7679's Avatar
Question Gauges
My coolant temp gauge and fuel gauge dosent work. I am wanting to just put a cheap temp gauge on and try to fix the gas gauge. What could make a gas gauge not work and how do i fix it and how do i install a aftermarket temp gauge? is it very hard?
Old Mar 15, 2009 | 10:15 AM
johnthegoalie's Avatar
thinkin with me dipstick
not hard, but with all electricals - it requires time and patience to route the wires so they dont look like a bowl of spaghetti. electrical gauges need a wire to the sending unit, a hot and a ground as well as hot and ground for lights. mechanical only need the lighting but you have to route capillary line.
Old Mar 15, 2009 | 12:39 PM
It might not be your fuel gauge but your sending unit, same with your temp gauge, or it could be a broken/shorted wire.
Old Mar 16, 2009 | 05:24 PM
same with me
my fuel gauge doesnt work
im pretty sure it is my sending unit
Old Mar 16, 2009 | 06:37 PM
Crazy4Carz.Com's Avatar
Originally Posted by 67 GTX
same with me
There is a wire/clamp type thing that grounds the fuel sending unit on the fuel line as it goes into the tank. Check that, you may find your problem.
PS, it is not the wire on the sending unit. It is a piece of metal, like a thin strap that attaches the line to the sender.
Old Mar 17, 2009 | 03:06 PM
ok thanks
i'll check on that
Old Mar 18, 2009 | 11:05 PM
rr69half6bbl's Avatar
quick test. with the key on put test light end into the plug connector for the tank sending unit, if the light blinks on and off repeatedly then the wire is fine from the gauge to the tank , it is an intermitent signal supposed to go on and off. if it stays on the wire is grounded somewhere from gauge to the tank , that wire runs from the dash down the drivers side floor pan to under the back seat then through to the trunk and down through the trunk floor under the spare tire. If no signal then the wires ither shorting out or the gauge isnt working, if the sifnals fine then its the graound strap crazy mentioned or the sending units bad.
srt425
Oct 1, 2010 02:50 AM
72Dartman
May 10, 2010 01:59 PM
68 Sat
Dec 7, 2009 01:00 PM
roy282
Dec 1, 2007 05:46 PM
trt100
Nov 18, 2007 04:49 PM
