Header Bolt Issues
Old Oct 18, 2019 | 03:24 PM
hkestes's Avatar
Header Bolt Issues
I have a 360 Magnum in my 37 Plymouth Coupe and have an issue with the header bolts coming loose over time. Have to tighten them every few hundred miles. Using ARP stainless bolts and the washers that came with them.
This is my first Magnum all other Mopar V8s have been big blocks or LAs. Is this a common issue with the Magnums?
Old Oct 18, 2019 | 06:20 PM
What type of gasket are you using?
Old Oct 19, 2019 | 02:58 AM
hkestes's Avatar
Remflex they had a lot of good reviews.
Old Oct 19, 2019 | 09:30 AM
They don't leak but they compress forever. But that's what I was looking for.
Old Oct 19, 2019 | 01:38 PM
These kick azz if you have bolts that vibrate loose all the time>>>>> https://www.lawsonproducts.com/Nord-...Steel/58098.lp
But if its just the gasket keeps crushing.... Thats a whole other issue
Old Oct 19, 2019 | 02:25 PM
You can try them but IMO it just takes finding the crush limits of the gaskets.
Old Oct 19, 2019 | 04:16 PM
Agreed
Old Oct 19, 2019 | 04:17 PM
Those heads in the photo are Magnum Heads?
Old Oct 19, 2019 | 04:20 PM
Also... I have found over the years that exhaust systems that are mounted to rigid always have a tendency to work loose and cause leaks at times.
Old Oct 20, 2019 | 06:06 PM
hkestes's Avatar
Yes they are Magnum heads, but I have LA valve covers. Work great with no leaks so far. Just used a little form a gasket on the gaskets when I assembled them.
Doba76
Mar 30, 2017 08:14 AM
Roadrunner1
Dec 1, 2016 12:52 PM
Robert Weaver
Sep 21, 2014 12:07 AM
Skynyrd
Aug 22, 2014 05:24 AM
PK1
Jun 10, 2012 04:20 AM
