Hissing PCV Valve
Old Jun 22, 2011 | 06:59 PM
jar84203's Avatar
Member
Hissing PCV Valve
I seem to have a problem with PCV valves hissing. I installed a Fram on my 71 Duster 225 and it hisses. I then installed a premium CarQuest valve (Wells I think) and it hisses. The grommet and hose are both new and are not leaking. It's kinda annoying...and not normal I would imagine. Any ideas?
Old Jun 22, 2011 | 07:59 PM
Barfly's Avatar
When I bought my truck, '72 340 cid the PCV valve rattled. Like open/closed very fast. I replaced it and it stopped the rattle. But I noticed in the process that it rattled more when the engine was cold and less as it warmed up.
I did not have a vacuum gauge at the time but my guess is that when the engine was cold there was less vacuum to open the valve.
I also noticed a vibration along with the rattle, do you feel any kind of vibration?
However mine never sounded like a hiss that you describe.
Not much help I know, but hope you get it figured out.
Joe.
Old Jun 23, 2011 | 08:47 AM
jar84203's Avatar
Member
The noise is there when it is cold and hot and it doesn't rattle any. What are the chances of two bad valves?
Old Jun 23, 2011 | 02:34 PM
Barfly's Avatar
My knee jerk answer would be more likely the wrong valves rather than two bad ones. Also I can't get passed the "hiss" as that sounds like a leak, but I know you said you checked??? I guess I'm of no help.
Joe.
Old Jun 23, 2011 | 05:55 PM
Crazy4Carz.Com's Avatar
PCV is supposed to rattle. Hissing is a vacuum leak.
Old Jun 23, 2011 | 09:34 PM
jar84203's Avatar
Member
I put a clamp on the hose and moved the valve around in the grommet to see if the hiss would go away and it did not...Ill have to investigate further
74Runneer
Oct 17, 2015 10:32 AM
josehf34
Mar 8, 2014 08:26 AM
Manoharvalves
Sep 15, 2011 10:53 PM
bushwood
May 24, 2011 07:50 PM
TCPMeta
Jul 15, 2007 09:23 AM
