How the heck do I remove the gas pedal?
Old Sep 28, 2009 | 03:50 PM
Lstroeh's Avatar
I have a 68 fury III that I am disassembling to prepare for paint. I made big progress today but upon removing the carpet, I realized the front half wouldn't budge because the hinged gas pedal flap thingy that makes contact with the actuator arm was somehow attached to the floor. I went under the car to discover 2 nuts attached to bolts which I presume are holding it down but after almost an hour of loosening the nuts the pedal still won't budge and the nuts won't come off. There is a rubber boot that covers where the bolt heads should be so I can't tell if I am making progress. I almost popped a vein on my forehead!!!Please help me Thanks!
Old Sep 28, 2009 | 04:57 PM
Crazy4Carz.Com's Avatar
Those "bolts" are studs. They should not turn. The nut should come off separately and the stud remain in the pedal assy. At this point you can:
A. Mask it and paint around it.
B. saw off the studs and nuts and buy a new pedal assy.
Those are pretty much your only options.
Old Sep 28, 2009 | 05:42 PM
Lstroeh's Avatar
Thanks I'll see if that helps, I think it may come to sawing
Kevin Pfau
Jul 22, 2014 06:07 PM
olibass1
Apr 22, 2011 07:10 AM
1972GoldDuster
Jun 24, 2010 06:05 AM
dodgenut7
Jun 2, 2010 04:39 PM
moparmatt
May 19, 2010 04:00 PM
