Ignition set up, need help
I just got my ignition system from fbo today and I'm trying to hook it up to my 318. My old ignition module had 5 pins coming from it and my new one only has four. Can I use the samewiring harness? Also its supposed to eliminate the use of a ballast resistor. How do I just take that out?
Coil set up: there is 1 positive wire and 3 negative ones. One of the negative ones is about 4 inches long with a cylinder at the end and grounds to the intake. My question is, where do I ground it to? The coil mounting bolt or the intake manifold bolt?
this should give you the info you need.
http://www.allpar.com/fix/electronic-ignition.html
basically the 5 pin box was first. it used 2 wires to take power into the box. the later 4 pin box uses only 1 wire to power the box. the resistors are diff, so check the diagrams for that. big hint which ever resistor you use get 2 extra put them in the glove at the first no start just swap one out. cold or hot weather makes it worse.
Does anyone know if this is a 4 point ballast resistor? ![Ignition set up, need help-ignition1.jpg](/forums/attachments/f62/7686d1484274182t-ignition-set-up-need-help-ignition1.jpg)
This is a wire that went to the negative stud on my coil??? It goes behind my break booster. Anyone have an idea of what this is?![Ignition set up, need help-ignition2.jpg](/forums/attachments/f62/7687d1484274182t-ignition-set-up-need-help-ignition2.jpg)
This is the negative that goes to the control module. Looks normal.![Ignition set up, need help-ignition3.jpg](/forums/attachments/f62/7688d1484274182t-ignition-set-up-need-help-ignition3.jpg)
This is the positive wire to the coil.![Ignition set up, need help-ignition4.jpg](/forums/attachments/f62/7689d1484274182t-ignition-set-up-need-help-ignition4.jpg)
Do these wires look like they might go together? They black wire goes to the ac compressor near the pulley, and the brownish wire comes from a cylinder looking thing on the condenser. What do you think?![Ignition set up, need help-ignition5.jpg](/forums/attachments/f62/7690d1484274182t-ignition-set-up-need-help-ignition5.jpg)
This is a wire coming from the negative stud of the coil. Is this the noise suppression for the radio?![Ignition set up, need help-ignition7.jpg](/forums/attachments/f62/7692d1484274182t-ignition-set-up-need-help-ignition7.jpg)
I still dont know what this wire is??
![Ignition set up, need help-ignition8.jpg](/forums/attachments/f62/7693d1484274182t-ignition-set-up-need-help-ignition8.jpg)
Does anyone know if this is a 4 point ballast resistor? Attachment 7686
This is a wire that went to the negative stud on my coil??? It goes behind my break booster. Anyone have an idea of what this is?Attachment 7687
The red wire with the eyelet is not a factory wire, and I cannot tell what/ where it goes
This is the negative that goes to the control module. Looks normal. Attachment 7688
This is the positive wire to the coil.Attachment 7689
For the suspect positive coil wire, see if it has power with the ECU unplugged
For the suspect neg. coil wire, it should only go one place -- back to the ECU connector, and should not have power with the ECU unplugged.
Do these wires look like they might go together? They black wire goes to the ac compressor near the pulley, and the brownish wire comes from a cylinder looking thing on the condenser. What do you think? Attachment 7690
This is a wire coming from the negative stud of the coil. Is this the noise suppression for the radio? Attachment 7692
Thanks 440! Im thinking that red wire with the eyelet might be the aftermarket tach thats in it. I followed the negative wire back and thats all good.
That radio noise suppression cap belongs on the pos side of the coil??!!
I would say yes. Easy to check. Put a test lamp on it and switch the key to "run." Work the AC/ heater controls to select AC, make sure the temp control is "cold" and if you don't get power, jumper around what you are calling "a cylinder" which is the low pressure switch
![Ignition set up, need help-1.jpg](/forums/attachments/f62/7701d1484274182t-ignition-set-up-need-help-1.jpg)
![Ignition set up, need help-3.jpg](/forums/attachments/f62/7703d1484274182t-ignition-set-up-need-help-3.jpg)
Is this right?
Think of the neg. side like this. Originally, in a breaker points system, the distributor had a SIMILAR cap inside the distributor. In reality, this cap (condenser back then) SHOULD be a specific value (microfarads) to match the characteristics of the coil. In the older books, there used to be photos of pitted points. If the points pitted on the ground side, the cap was ( forget big or small) the wrong value, and if pitted on the "hot" side, the value was wrong towards the opposite way
Obviously, adding a radio cap to the NEG terminal would INCREASE this value quite possibly more than double!!!
The Mopar system actually has a cap inside the box which replaces what used to be in the distributor. You would not want to install a huge additional cap to the neg coil terminal.
Attachment 7701This is a picture from about a year ago. The wire from the ac looks like it does go to that brownish wire going to this. Attachment 7703
Is this right?
Is this right?
Normally, there would be a quick connect there, not a butt splice.
a.johansson84
05-27-2012 03:30 AM
GMdude
07-09-2009 04:42 PM
