Ladder bar question
Old Sep 22, 2009 | 02:47 PM
68 gtx's Avatar
Ladder bar question
Im installing a ladder bar set up and trying to figure out if the lower bar should be level with the frame.Thanks in advance
Old Sep 27, 2009 | 07:23 AM
rr69half6bbl's Avatar
68, the bar should actually be centered on the frame rail from top to bottom. your bolting it to the frame i assume. and then your using clamps for the axle tube side, if you weld them in place then your asking for problems. you have to have a little flex or it will ither twist the body permanatly out of shape or bend your tubes. Id rather see you tie the frame together with connectors. good luck
Old Sep 27, 2009 | 04:46 PM
68 gtx's Avatar
i ended up tubbing the whole back half.thanks for the info.I bought the car from a guy the was turning it into a drag car but i want something i can drive on the street. i will post pics soon
Old Sep 27, 2009 | 05:57 PM
your welcome, thats why were here. sounds cool, are you going to use a 4 link now ?
bc18
Nov 18, 2008 01:51 AM
AirBorne
Apr 19, 2008 04:02 AM
1cerberus4u
Apr 18, 2008 06:55 PM
lemontwist73
Feb 10, 2008 12:21 AM
krsboz
Sep 23, 2007 09:10 PM
