leaking oil?
Old Oct 11, 2010 | 08:06 AM
ChargerBoy'71's Avatar
leaking oil?
I just put my new edelbock intake on the 318 and my Mopar Performance valve covers dont seem to fit very snugly and they seem to leak oil. Any suggestions?
Old Oct 11, 2010 | 11:30 AM
what type of gasket did you use?
you might have overtightened the gasket, or not tightened it enough
Old Oct 11, 2010 | 12:19 PM
fivepoint's Avatar
Are they the same covers you had before?
Old Oct 11, 2010 | 01:47 PM
I torqued the covers to 80 inch/lbs.
And yes, they are the same covers i had with the old intake.
Old Oct 11, 2010 | 03:19 PM
Polaradude's Avatar
Maybe run a small bead of rtv around.
Old Oct 11, 2010 | 04:21 PM
ill try that, thanks guys!
Old Oct 11, 2010 | 06:45 PM
rr69half6bbl's Avatar
The mp covers, i think are not good for sealing, every motor Ive worked on for people theyve leaked, massivly. Ive had to use the mr. gasket compressible gaskets w/ the steel cores. adn then rtv the heck out of them especially on the bottom rail between the middle two bolts on the bottom side of the cover, i have also found that they warp after a season or two. same area, they shrink up a tad. I never ran them because of all the probs, Ive seen w/ other people.doesnt matter ither small block to big block, they all have the same prob. especially w/ headers. the #1 tube runs over the top and so close to the bottom of the cover that all that heat just attacks the bottom of the cover.
DusterDude88
Sep 9, 2012 09:42 AM
ChargerBoy'71
Oct 28, 2010 05:52 PM
jtvisco
Nov 8, 2009 03:38 PM
wrenchn365
Oct 8, 2009 01:20 PM
dzltd02
Oct 28, 2008 08:25 AM
