Losing fire
Old Feb 7, 2011 | 02:21 PM
starfleet's Avatar
Losing fire
Have a 77 Pace Arrow rv with a dodge 440 engine and dodge electronics. I have replaced Ignition module, distributor, starter relay, ballast resistor, ignition coil, ignition switch, when the vehicle is cold it will start right up and run for 45 min to an hour then dies like someone turned the key off and then it won't restart it seems to have lost power on the negative side of the coil very dim on the test light an no pulse to coil HELP PLEASE
Old Feb 7, 2011 | 02:42 PM
MercuryDon's Avatar
Does it have athe leab burn system ? If so you should convert it to a non lean burn.
Old Feb 7, 2011 | 06:37 PM
will d's Avatar
check your fusible links out real good, i had a similar problem when one burnt up.
Old Feb 7, 2011 | 07:35 PM
starfleet's Avatar
losing fire
actually both fusible links on the starter relay were changed when i changed the relay and as far as the lean burn system i don't believe it has it because it is a 77 pace arrow RV
mdrexel
Sep 9, 2013 06:48 PM
383newport
Aug 22, 2012 02:59 PM
69Bee
Jun 1, 2009 09:34 AM
chavlics
May 29, 2009 02:36 AM
wht96
Mar 31, 2008 11:21 PM
