lug nuts
lug nuts
I cant break the lug nuts loose on drivers side front on 68 barracuda. I don't have access to an impact wrench. Is it righty tighty lefty loosy? I heard the threads may be different. I really don't want to break a stud. I've even tried a cheater pipe but didn't try super hard because I may be tightening them. I've had the car over 2 years and this is the first time I've had to take a wheel off. any ideas? It does have disc brakes on front if that means anything. Can't see the stamp on studs because of the lug nut covering it. thanks
http://www.jimsautoparts.com/wheels.htm
on the site above you can see that the correct lugs for them were left and right threaded as stated in the post above you may only have a few left that are original as previous owners may have already used the cheater bar and had head trauma and snapped the lugs off not knowing the correct threading but the true question is, once you get the tires off are you gonna put on the correct ones or make them all lefty-loosy
lug nuts
Hey what really screw with your head is when some one changes the brake drums from side to side. Then you have left and right on both sides just opposite on each. (front to back) ..
Anyway, just ask 78D200, he is THE expert on left hand lugnuts!(hehehehe)
BigYellow
24
05-06-2014 08:17 PM
