Manual to power brakes
Old Jan 21, 2014 | 08:21 PM
1968GTX's Avatar
I was wondering how much is involved into converting my GTX, from manual to power brakes. I need to replace all my brake lines and master cylinder anyways. Is there much more to do to make them power? It still has 4 wheel drums.
Vinnie.....
Old Jan 24, 2014 | 06:34 PM
chlngr1970's Avatar
Proportioning valve, power brake booster, backing plates on the front... are you talking about front disc, or 4 wheel disc?
j
Old Jan 24, 2014 | 07:21 PM
Install a power brake booster between the master and firewall. Everything else is the same
Old Jan 24, 2014 | 08:07 PM
1968GTX's Avatar
Is that for keeping the drums on all four? I can't afford doing a disk upgrade. All though I'd like to, maybe later.
Old Jan 24, 2014 | 09:19 PM
moe7404's Avatar
from an engineering stand point the pedal arm on power and non-power have a different lever ratio, generaly. but i dont know if car makers always do it like that. your car might use the same arm for both. i am not sure. and master and wheel cyl sizes enter into this allso. so like so many car things it is a system. not one thing at a time. a cam and carb does not a race car make.
Old Jan 24, 2014 | 09:54 PM
Yes with the drums. The pedal arm is different.. IT is part of the power booster
Old Jan 25, 2014 | 06:55 AM
My two cents says stay manual but upgrade to front disk brakes. That what I did with my 440 Dart and it stops fine.
Old Jan 25, 2014 | 10:40 AM
chlngr1970's Avatar
I completely ignored the part about not converting to disc brakes. Sorry. But, I agree with Bremereric, go manual disc, over power drum. I have manual disc on my Duster. 8:80 in the 1/8th, and never had a problem stopping.
j
dodgeman68
Jan 12, 2013 05:15 PM
HonkyCat
Nov 3, 2012 10:09 AM
thedusterridesagain
Sep 20, 2012 07:57 PM
Jwhis
Mar 19, 2012 04:09 PM
Rbaisch
Dec 1, 2008 02:17 AM
