might have found a work car
driving home today i just happened to see a front end of a 76-78 volare/maybe roadrunner,R/T gonna stop there tomorrow and see, is there anything i should look for on this type of car? im thinking it is a performance model the grille looked like the r.r / r/t 's were
well i kinda narrowed it down today im pretty sure it is a 77 still couldnt really get close to it as it is in a fenced in yard and hard to see from the street the place was closed by the time i got off work yesterday im leaning more towards the r.r. version its parked inside of a pawn shop so im gonna call today about it
on
although the late 70`s mopes arent like the desired 1`s, they still made them with manual trans and small blocks, a guy can really work 1 over w a 360 and a kiesler 5 speed, and make a rocket out of it.
well hell E sounds like you might have a great start for a drag car if that what you meant by a work car or if its to drive back and forth to work im sure that will get you a few more miles on a tank either way let us know what you find out ok
p.s if i remember right the 76/77 front ends on the V and the RR looked the same so you will have to either get up close and look at it or like you said call them and see what they got
well guys i've got to see alittle more of it kinda hard to look backwards and drive fowards but us mopar peeps know the technique, gonna go there friday after work they should still be open
Guest
Posts: n/a
unless it has a /6 you're looking at a 14 mpg daily driver (if it had a 318) more like 12 mpg at the most of its a 360.
idk - unless someone here is actually getting good gas mileage out of a mopar small block
i get 7 mpg on my '67 crewcab powerwagon - and i consider that good considering the air resistance and the fact that its huge and weighs 6440 lbs.
Guest
Posts: n/a
i dont mean to sound like an *** but i honestly find that very hard to believe. are you actually dividing the number of miles driven be the exact amount of gallons you put in the tank?
and **** if thats true - tell me about your motor and whats ur transmission, do you have O/D, and what are your rear-end gears, what rpm do you cruise at 70 mph, what carb and carb size, what heads, camshaft, and what all else you've done to that engine?
i mean ive heard of 440 cars getting like 12-13 mpg and to me thats sounds like excellent mileage for a such a huge engine...
i know the 440 powered dodge trucks got gas mileage in the single digits...
on
Hey stick, beleive it or not, gtx could be righ ton. I had a cuda that got 19 to the gallon. it was a 440, 10-1, 284-428 purple shaft, rhodes lifters, 2.14 intake and 1.88 exhaust valves. mild port job, 6bbl setup, I ran the felpro gapless rings, ( molly) , hemi 4spd, and 3.23 sure grip . when I stayed out of it, I got 19 to the gallon.ran 55 all the time( when I stayed out of it) roughly 2100 rpm`s at 55. tach and speedo were acurate, checked it to the wifes dailey driver, because i didnt beleive it at first myself.
Guest
Posts: n/a
theres just no one in my area that has a muscle car or carburated truck that gets anything close to "good mileage"
on
I used to get around 13 mpg with the 400 in the Cordoba, all around driving including stop and go and some highway. It had some power too, for it being pretty much stock.
Guest
Posts: n/a
not to sound rude, but wouldnt you do better with the smaller 1.81 exhaust valve?
ef8340
12-17-2008 12:07 AM
