might have found a work car
Old Sep 24, 2008 | 03:48 PM
ef8340's Avatar
Senior Member
driving home today i just happened to see a front end of a 76-78 volare/maybe roadrunner,R/T gonna stop there tomorrow and see, is there anything i should look for on this type of car? im thinking it is a performance model the grille looked like the r.r / r/t 's were
Old Sep 26, 2008 | 02:51 AM
ef8340's Avatar
Senior Member
well i kinda narrowed it down today im pretty sure it is a 77 still couldnt really get close to it as it is in a fenced in yard and hard to see from the street the place was closed by the time i got off work yesterday im leaning more towards the r.r. version its parked inside of a pawn shop so im gonna call today about it
Old Sep 26, 2008 | 03:45 AM
rr69half6bbl's Avatar
although the late 70`s mopes arent like the desired 1`s, they still made them with manual trans and small blocks, a guy can really work 1 over w a 360 and a kiesler 5 speed, and make a rocket out of it.
Old Sep 26, 2008 | 04:19 PM
challenger's Avatar
well hell E sounds like you might have a great start for a drag car if that what you meant by a work car or if its to drive back and forth to work im sure that will get you a few more miles on a tank either way let us know what you find out ok
Old Sep 26, 2008 | 04:22 PM
challenger's Avatar
p.s if i remember right the 76/77 front ends on the V and the RR looked the same so you will have to either get up close and look at it or like you said call them and see what they got
Old Oct 1, 2008 | 04:10 PM
ef8340's Avatar
Senior Member
well guys i've got to see alittle more of it kinda hard to look backwards and drive fowards but us mopar peeps know the technique, gonna go there friday after work they should still be open
Old Oct 9, 2008 | 06:49 AM
Hey ef, what ever happened w/ the car? did you stop and inquire about it?
Old Dec 17, 2008 | 01:29 PM
well, my 440 can get around 18 on the highway
Old Dec 23, 2008 | 06:17 PM
challenger's Avatar
hey SS i get about 6 mpg in my challenger hehehehehe
Old Dec 24, 2008 | 12:03 AM
Hey stick, beleive it or not, gtx could be righ ton. I had a cuda that got 19 to the gallon. it was a 440, 10-1, 284-428 purple shaft, rhodes lifters, 2.14 intake and 1.88 exhaust valves. mild port job, 6bbl setup, I ran the felpro gapless rings, ( molly) , hemi 4spd, and 3.23 sure grip . when I stayed out of it, I got 19 to the gallon.ran 55 all the time( when I stayed out of it) roughly 2100 rpm`s at 55. tach and speedo were acurate, checked it to the wifes dailey driver, because i didnt beleive it at first myself.
Old Dec 24, 2008 | 02:13 PM
Commando's Avatar
I used to get around 13 mpg with the 400 in the Cordoba, all around driving including stop and go and some highway. It had some power too, for it being pretty much stock.
moe7404
Jul 26, 2014 03:58 PM
MrsSnowtrooper
Aug 7, 2013 11:18 AM
moparboy
May 27, 2011 08:50 PM
ef8340
Dec 17, 2008 12:07 AM
