Mopar green bearings
The green bearings will get rid of the factory end play adjusters and retainers. Tapered bearings are desighned for axial(when your going around a corner) and vertical loads ( when your trunk is full), the bigger the bearing means less heat can build up and the components are stronger.
1966DartConvertible
11-25-2010 10:57 PM
