Mopar LA Hydraulic Roller retro fit
Old Nov 12, 2021 | 07:29 AM
PentStar_Power's Avatar
Hello all im in the midst of a new project and i want to switch my old 360 LA to a hydraulic roller set up. I know that comp makes a kit to do it but have not found a lot of information about ease and quality. Has any one else out there done a roller retrofit on a LA small block? If so who did you go with?
Old Nov 12, 2021 | 08:59 AM
I have an engine builder friend that builds a lot of mopars. He has had trouble with retro hydraulic roller cams in LA small blocks. Lifter bleed down or not pumping up fully. The last time I was there while he was working on a problematic sbm he was pulling the roller and putting in a flat tappet. The customer had had enough with the problem. He has only been installing flat tappet cams in sbm, no retro fits.
Old Nov 12, 2021 | 09:39 AM
ugh..... i was hoping to hear different lol. its such a pain to run flat tappet cams these days with the lack of soft metals like zinc in oil. I've been told to run a bottle of break in additive with every oil change to keep from wiping the cam.
Old Nov 12, 2021 | 10:36 AM
I know what your saying but problems with retofit sbm cams is real.
Minidak
Apr 24, 2013 11:09 AM
q8_barracuda
Dec 30, 2011 04:30 PM
bugy
Feb 1, 2011 08:51 AM
norcalmopar
Aug 6, 2010 03:51 PM
bad_karma
Aug 28, 2008 02:03 PM
