Mopar question
Old Oct 12, 2010 | 04:17 AM
minpins6780's Avatar
Mopar question
I have a 78 440 rv motor, that is 8 5 to 1. What would I have to mill my heads to, To get close to 10 to 1 compression?
Old Oct 12, 2010 | 05:27 AM
That is too much math for me to do but I'm sure that a local engine builder/engine shop could tell you.
Old Oct 12, 2010 | 07:40 AM
Archer's Avatar
m -
Bad move. If you mill the heads enough to jack the compression that much, odds are you'll have to mill the intake as well and that "might" lead to other fit problems. I'm sure it's been done, but not the route I'd take.
If you really want to increase the compression that much, look into a new crank, rods and/or pistons.
Old Oct 12, 2010 | 08:00 AM
1966sportfury's Avatar
A.K.A Bob Dodge
switch heads, that would probly be the cheapest route find a set of 915 closed chamber heads and that should get you closer to what you want,
Old Oct 12, 2010 | 08:22 AM
Originally Posted by Archer
m -
A good quality machine shop can mill the heads and intake to match and will not cause issues. I did it with a 383 BB I had. Everything fit much better after the work.
Old Oct 12, 2010 | 01:52 PM
i would never recommend milling a head to get another 1.5 compression
that could structurally weaken the head
i like 66's idea
915 should help
Old Oct 12, 2010 | 06:03 PM
scotts74birds's Avatar
I'm no mopar head expert, but shaving that much, wouldnt that require new pushrods too?
Old Oct 12, 2010 | 07:22 PM
Archer's Avatar
Tim -
Anything can be made to work. The amount of work ($$$) and additional parts work, like the pushrods Scott mentioned and possibly valve clearance issues (sorry don't know all the specs) just don't make it sound like the best idea, even if do-able. Now, if your uncle owned the machine shop
Old Oct 13, 2010 | 02:54 AM
If minpins6780 went with the 915 heads, would the puch rods still need to be replaced or are those demenitions still the same and only the combustion chamber size different?
Old Oct 14, 2010 | 03:44 PM
as a rule of thumb, if you pull apart a motor that you have no history on, you should double check the pushrod length and the tension that they are putting on the lifters
if you mill a head, you need to get new pushrods
if you just get a new head, if the height and everything is the same, you might be able to keep your old pushrods, but i am not entirely sure
to be safe, i would just measure
Jbalz
Sep 28, 2011 05:17 AM
