Mopar Rod Bolts Torque Spec
Old Dec 12, 2010 | 01:35 AM
nitrosdog's Avatar
Hi fellow mopar fans, can anyone tell me the torque spec for mopar rod bolts used with ARP nuts in magnum rods (318ci). Cheers, Dave.
Old Dec 12, 2010 | 08:50 AM
John Van's Avatar
Welcome! Should be 50 ft lbs. using arp lube,but you are better off measuring bolt stretch. Check the arp web site for better info.
john
Old Dec 17, 2010 | 11:30 AM
jaye73's Avatar
Arp rod bolts
There are several differant specs it all depends on the bolt is made of your best bet would be to ck out arp web site to get the spec. Mine are 12 pt 7/16 bolts and torque at 83 ft lb with molley lube
Old Dec 17, 2010 | 11:32 AM
jaye73's Avatar
Not 83 ft lb
Sorry not 83 I hit the wrong number I mint to put 63 ft lb
Old Dec 17, 2010 | 11:41 PM
nitrosdog's Avatar
cheers, thanks guys. I have checked and FYI they say the spec is 45ft lb...... think I take them to 50.
JETBLU
May 1, 2015 04:05 PM
packrat56
Apr 25, 2014 06:21 PM
Caravandalism
Aug 16, 2012 07:10 AM
kartman48
Jul 1, 2011 06:49 PM
1973charger
Jun 4, 2009 11:40 AM
