my 360 build
Old Mar 2, 2013 | 08:48 AM
carkindaguy's Avatar
my 360 build
i was just wanting to see what everyones opinion is on what kinda power #s my 360 build will make?
the build
motor is 360 .040
%100 cnc ported eddy head by hughes engines
2.08 intake, 1.60 exhaust
10:5.1 comp
lunati cam solid flat
Lift .546"/.566" Dur.@.050 243/251 LSA/IAC 110/106
hughes light weight coolface solid lifters
hughes roller rockers
eddy rpm air gap intake
holley ultra 750 double pumper
eagle floating sir rods
kb flat top pistons
hughes oil threw pushrods
mallory billet dist.
msd plug wires
tti headers
k&n air filter
kevco oil pan and pickup
its all going into my 74 duster with 3500 stall, 727, 430 or 456 gears. so what will my #s be?
Old Mar 2, 2013 | 10:26 AM
Gorts 5th's Avatar
Smile
at least 1.5 hp per c.i.
456 gears a strip car only eh?
trailer there trailer back?
Old Mar 2, 2013 | 10:33 AM
it might see the strip once or twice. its for putin around town on the weekends.
Old Mar 2, 2013 | 10:46 AM
Gorts 5th's Avatar
Smile
3.55 gears will be more street friendly
Old Mar 2, 2013 | 12:16 PM
not worried about the gears ive already selected. im not worried about street friendly. i just wanna know what everyone thinks the power will be like?
Old Mar 2, 2013 | 01:11 PM
PK1's Avatar
PK1
with out knowing the final bob weight, valve stem diameter, piston and crank material, i would speculate 460 HP / 440 TQ.
I would say power in around 3600 - 6600. She is gonna be a beast!
Very well thought out build. Nicely matched parts. You did your homework. I don't see your spring listed so have Dave put the right one on before he ships the heads. The Eddy head uses a Chevy rocker so go slowwwwww when you set the geometry via PR length. And tune it with a wide band for sure.
Old Mar 4, 2013 | 06:18 AM
Gorts 5th's Avatar
Smile
yep she will be a beast.
i ran a m.p. 270 cam with eddy rpm intake and headers/duels on my 86 3500 tradesman work van, 5860 was the average weight of the vehicle tools and all
518re w 411 gears she was a beast use to fear breaking a u joint, that motor pulled so friken hard! oh yea i forgot to mention i was running solid lifters on that cam. i use to switch between a holley 600, or 750 vac depending what i was using her for, big difference in how she performed. i ran a few furdschebbies over the years... couple lightniez... she held her own never went away ashamed.
the rest of the motor was stock...
dodge6890
Jan 22, 2012 09:58 AM
stickshifted
Nov 6, 2010 08:56 PM
85dodgeram350
Jun 23, 2010 12:01 AM
irishman
May 29, 2010 05:07 PM
ed22
Oct 3, 2009 01:33 PM
