need help 440 miss
Old 09-01-2009 | 08:24 PM
crmzendrgone's Avatar
I am just throwing this out there cause it sounds good and I know more knowledgible people will have the right or closer to right answer than me but I am saying maybe valve train? cam? lifters? pushrods? Thats me sense you gone throught the fuel/air and spark part I can only think mechanical.
Old 09-01-2009 | 09:23 PM
have you checked the resistance in the wires where the cylinders went bad?
Old 09-01-2009 | 10:12 PM
theomahamoparguy's Avatar
the "all of a sudden" part makes me think that something broke [maybe in the distrib. or even a crack in the intake manifold] I dont think the cam got wiped out cause thats not an "all of a sudden" type thing. THe reason im thinking crack in the manifold is because if a crack occurred in the dual plane manifold in the right place it would disturb cylinders on both sides of the engine [cause of the design of the dual plane intake]. Another thing could be the bushing in the dizzy coming apart and its arcing out or not able to produce a signal. Do you know if the cylinders in question are in a sequence that corresponds to the firing order? {eg: 6-5-7} Just some thoughts, hope they might help or give you something to ponder. Good luck and make sure to get back here and; WELCOME TO THE FORUM!!!
Old 10-01-2009 | 07:43 PM
Commando's Avatar
You solve this issue yet?
I assume you checked the basics fluid wise, always a good place to start.
Any of the rods bend, slight stretch, but possible solution.
Old 10-02-2009 | 03:08 AM
What was the compression of the all the cylinders? Have you installed a spark tester to make sure that you were getting spark?
Old 10-02-2009 | 04:20 AM
Polaradude's Avatar
How's your timing relative to TDC, Is it possible you may have a stretched timing chain and skipped some teeth ?
scott2683
06-27-2010 09:22 PM
familyevents
12-29-2009 10:24 AM
carlosg7915
09-08-2009 07:48 PM
64fury
07-08-2009 09:53 AM
06-13-2009 09:43 AM
