need help with brake power booster and master cylinder
Old Jul 12, 2023 | 07:01 PM
565bigblock's Avatar
I have a 66 plymouth barracuda what I have is drum brakes all around the car with a power booster and single resavoir my booster has four studs in the back of it to mount to the bracket and four studs in the front to install master cylinder the master cylinder no problem that is easy but where can I get this power booster it is driving me crazy!! please help me
this is what I have
Old Jul 14, 2023 | 07:54 AM
Check to see if you have a local rebuilder? If that dose not pan out.... Call and see if you can send it to be rebuilt over at CARDONE?
​​​​​​https://www.cardone.com/
Old Jul 16, 2023 | 03:19 PM
Lostviking's Avatar
Did you try napa? The one here in Chula Vista has it in stock I believe, $135. That might not be the correct one, but they have a bunch of different ones when I searched for 66 Barracuda. Some a lot cheaper too.
nballen_W100
Nov 13, 2022 03:38 PM
Randyscharger
Apr 13, 2020 03:11 PM
topferment
May 21, 2012 11:20 AM
Mixmastermerrill
Oct 20, 2008 09:22 PM
