need help with this noise
Old Jul 14, 2009 | 06:26 PM
scotts74birds's Avatar
Could be different "backspacing". The distance between the back of the rim and the hub mounting surface. or a wider rim and tire combo.
Old Jul 15, 2009 | 06:01 AM
64fury's Avatar
Did you check the bump stops? are they still in place?
What size tire are you running, bigger than stock?
Old Jul 15, 2009 | 06:10 AM
Could have a broken or worn out bushings or suspension componant. If it is the factory wheels, or a whel with the same specs, then maybe the tire is taller than stock. There should be a sticker on the door that tell you what size tire, what size wheel, and at what PSI to run the tires at.
Old Jul 15, 2009 | 10:25 AM
Mopar_71's Avatar
How big are the passengers??
Old Jul 15, 2009 | 11:29 AM
That is the tire size and rim size that should be on the car. If you have 17" wheels, they could be from another vehicle or aftermarket. 205/55R16 is ~24.9" tall tire. If you are running a taller tire, on a larger wheel, that could be the reason why it is rubbing. I would also look at the spare and see the size of that tire. Usually they are the same height as a change in height on the drive axle would break the tranny on a FWD car.
Old Jul 15, 2009 | 01:35 PM
challenger's Avatar
is there a way you could send a picture of the struts in the rear and where it is hitting with the tire in place .... a picture would help us determin more of what your problem would be
1966charger
Apr 22, 2012 08:35 PM
doug2060
Aug 28, 2010 04:33 PM
MichaelSB
Aug 16, 2010 12:08 PM
Valcam
May 1, 2009 03:10 PM
mopar nate
Mar 21, 2009 09:16 PM
