need opions on making power
Old Jul 11, 2010 | 08:50 PM
Dartman91's Avatar
i have a 73 dart with a 360 it feels like its lacking power.. Im new to mopar so i dont know much about them i would apreciate tips on were to get the most power out engine
Old Jul 11, 2010 | 09:16 PM
1966sportfury's Avatar
A.K.A Bob Dodge
dump the 360 and go to a 318!!
seriously tho, what was done to the engine? if its stock or close they dont have much pwr, due to lack of comp, and cams they are not much of a engine in stock form,
Old Jul 12, 2010 | 10:29 AM
like 66 said, is there any work done to it?
Old Jul 12, 2010 | 05:15 PM
Bore it , stroke it and cam it!!!!!!!
Old Jul 12, 2010 | 08:53 PM
Dartman91's Avatar
all it has is mild lunati cam with edelbrock single plane intake and a few other things that dont add power like stiffer valve springs also im looking into to buying a new carb whats a good size it has a 650 holley but im thinking bout going with a pro form thanks for the input
Old Jul 12, 2010 | 10:26 PM
A.K.A Bob Dodge
no reason to spend $$ when you dont need to switching to a pro-form wont gain you any noticeable power, they both are very good manufactures, the single plane manifold will hold back power in the lower end most single plane manifolds are made to produce power at 2500+ rpm range, wile your manifold builds power to 6500-7500 the cam is out of power range, instead of buying a new carb, id either switch to a dualplane or invest in higher comp pistons, with a bigger cam to justify a single plane manifold
Old Jul 13, 2010 | 05:02 PM
do you know what compression you are running now?
Old Jul 13, 2010 | 11:34 PM
Tiretrack's Avatar
Junior Member
You should probably swap out the single plane, that will raise the power band way up in the rpm range, and unless your driveing at Higher rpm's all the time, a duel plane would make it feel a bit more torquey at your normal drivring rpm range.
67Polara
Aug 4, 2009 04:37 PM
1973charger
Jun 4, 2009 12:36 PM
78trailduster
Mar 30, 2009 03:30 AM
deadkelly
Jan 22, 2009 04:08 AM
TheKneeBita
Sep 6, 2008 12:52 AM
