Neutral safety
Old Jun 6, 2016 | 02:23 PM
John 64 Fury's Avatar
Neutral safety
Anyone know the exact location that the brown wire coming from the transmission neutral safety goes(64 Fury 727 transmission - 1 wire)? Picture would help. I assume starter relay but already wire coming from the wire harness there.
Old Jun 6, 2016 | 06:56 PM
John... Welcome..
You are rite...
Brown wire goes to the starter relay....End
Yellow from the relay to the Starter Solinoid...Center
Yellow to the ignition Switch.....End
You can fined the wiring info over at MyMopar
http://www.mymopar.com/downloads/196...FurySavoyA.JPG
Keep us posted....
Old Jun 6, 2016 | 08:28 PM
wire on starter relay
looks like whoever owned my car befor bypassed the neutral relay.
If you look at my picture attached all lugs are full and the neutral wire is just hanging beside it. \Any ideas?
Old Jun 7, 2016 | 08:56 AM
I see.... So the car is starting while in Drive or at any time you command it?
Rite?
Old Jun 7, 2016 | 08:52 PM
Never tried to start in gear but the car does start. i didnt notice the loose wire until i rebuilt the engine and saw it was unhooked.
Old Jun 8, 2016 | 07:50 AM
Might be possible that the wire had a problem and someone just ran a new wire instead of unlooming the whole harness?
Also... I think I would test it in Drive to make sure it will not turn over while in gear. that way you know for sure if its even hooked up or not.
Just my 2 cents....
Old Jun 9, 2016 | 08:20 PM
I am just putting a new carb on definitely going to try to see if it starts in gear. I say thats a bit of a safety hazard.....
Old Jun 9, 2016 | 08:29 PM
Better to know than not to know.... Thats for sure...
Old Jun 12, 2016 | 09:02 AM
I checked out another old dodge and found that mine was shorted out to the relay and yes would start in gear. So i corrected the connection and works well now.
Old Jun 12, 2016 | 09:28 AM
That's good,..... I know of a very nice 67 chevelle ss 396 that got driven through the back of a garage. It went through a work bench a toolbox first.
Old Jun 12, 2016 | 10:21 AM
Glad you got it squared away John....
Old Jun 12, 2016 | 06:47 PM
got the neutral safety sorted but blew my muffler apart.......awg. Cant win lately. I guess gas build up in muffler. I was repairing the carb throttle linkage and trans kickdown and must have floaded it a bit.. i was going to change exhaust but not now... now no choice...
Old Jun 12, 2016 | 06:59 PM
Oh My...... Sounds like it might have had some holes in the exhaust and allowed a little to much air in, and then lit off the fumes....
So are you going to be looking for the Stock system or more of a Hot Rod Sound?
Old Jun 12, 2016 | 07:14 PM
wanted dual exhaust, it was single exhaust and muffler was not good. Car has a 318 polyspere just rebuilt. thinking more stock "quiet" exhaust with cross over. Whats your thoughts on exhaust. Just rebuilt motor stock with mild cam
Old Jun 13, 2016 | 10:45 AM
I would agree.... Nice Dual exhaust with a set of Turbo Mufflers 2" or 2-1/2"
Out the back with a couple of chrome tips.. Cross over Pipe, If it will fit nice... Would sound great....
http://www.thrushexhaust.com/muffler...ter-17702.html
Dec 1, 2011 05:24 AM
Aaron.Albrecht
Jul 30, 2011 10:24 AM
Derek77PW
Jul 16, 2011 08:33 AM
Dave MoorePower
Aug 11, 2008 05:59 AM
hemihead
Mar 18, 2008 03:23 PM
