View Poll Results: What should i do
Change motor
25.00%
Rebuild motor
25.00%
Put crank and bearings
50.00%
Voters: 4. You may not vote on this poll
Not sure what to do
Old Nov 17, 2017 | 05:26 AM
KINGPSYCO's Avatar
Not sure what to do
I'm new to this forum not sure I should post this. I have a 02 Dakota (this is only my 2nd dodge to deal with) I'm not impressed with dodge. Anyway. It has a 4.7 motor 4×4. Oil pressure dropped. I shut it off quick. Now it has a knock. Was trying to see what would be the easiest and cheapest way to get it going again. I really don't like working on my own vehicles but i will if need be. Again what would be the easiest and cheapest way to get it running.
Old Nov 17, 2017 | 03:45 PM
fivepoint's Avatar
More information needed for a better vote. Miles on motor, compression results. I'm not sure but can the oil pan be removed without pulling engine?
Old Nov 17, 2017 | 08:38 PM
If it is a 4x4 ? the front diff gets in the way. I would pull the motor and turn it upside down and inspect the crank & bearings
Old Nov 18, 2017 | 08:30 AM
Opinion. Difficult engine to rebuild, not a good engine.
If it was mine I'd first look at a used replacement engine drop it in and hope for the best and probably sell it. If I planned to keep it I'd get a 5.9 L V8 with the computer and wiring and convert to this better engine.
Old Nov 18, 2017 | 10:57 AM
Put a Recon motor in it or send that one out to be rebuilt.. Or just cut and run and sell it as is..
D4Dartswinger
Apr 7, 2017 02:50 PM
Mike Williams
Apr 16, 2016 05:15 PM
1OldFordMan
Dec 18, 2012 06:21 PM
Slayer44
Jan 2, 2011 03:29 AM
bigdaddy
Jul 2, 2008 05:29 PM
