Overheating
Overheating
I've got a 65 Polara with a 2 barrel 383 that overheats. Last year it also overheated but a new water pump and thermostat stopped that. Now it overheats again. I installed a new radiator cap and a about three years ago the radiator was rodded out at a local shop. What could be the problem? Thanks in advance.
Guest
Posts: n/a
a bad thermost will usually give you a knocking sound when you turn off the motor and the water starts to boil. it is soon followed by it puking the water out.
spray some water on the radiator after you stop a hot engine. see if the water eveaporates evenly or if there are spots that stay wet. it might indicate a section of the core that is plugged.
if there is a fan clutch is it operating properly?
is the shroud missing?
have you checked the timing?
you can also have a buildup of rust in the cooling passages in the engine.
when the thermostat opens do you see a good flow of water.
a thermostat that is stuck open can flow the water too fast to let it cool.
is it really overheating or is the guage just reading high?
53cranbrook
01-11-2013 06:31 AM
