penatrating oil comparisons from roadkill kustoms
Old Aug 3, 2012 | 02:24 AM
mosquito13's Avatar
Rusty Nuts and Bolts? Make Your Own Super Rust Penetrant!
Since its invention in 1953, WD-40 has been the go-to solution for many household and garage problems. Over the years, other companies have come up with their answer to WD-40's penetrating properties such as Liquid Wrench and Kano Kroil. Others have tried their own home-brewed concoctions in the never-ending battle against rusted nuts and bolts. Our favorite is a 50/50 mix of acetone and Dexron/Mercon Automatic Transmission Fluid.
Simply mix one part acetone and one part ATF in a re-fillable spray bottle and go to town. The idea is to thin the ATF with the acetone so it will penetrate and seep into and between surfaces. The acetone will evaporate, leaving the oil to do its job. Because the acetone evaporates so quickly, it's a good idea to mix this in small batches.
Skeptical? We were too. Then we did some poking around on Google and found that in the April 2007 issue of Machinist Workshop Magazine, they performed subjective independent testing of penetrating oils using a single steel bar with 1/2" x 20 nuts torqued to 50 ft/lbs and treated with a 10% salt water solution that was allowed to rust.
Listed are the chemicals tested and the respective required removal torque:
None
516 pounds
WD-40
238 pounds
PB Blaster
214 pounds
Liquid Wrench
127 pounds
Kano Kroil
106 pounds
50/50 Acetone / ATF
53 pounds
Old Aug 3, 2012 | 02:28 AM
Thats pretty good to know.
Old Aug 3, 2012 | 07:53 AM
BuckNeccid's Avatar
And I always keep acetone on hand cause it's so handy. Think I'll try it with MEK too, it evaporates even faster, and is hot enough that it will tend to soften any paint buildup that may be there
Old Aug 20, 2012 | 06:07 AM
Gorts 5th's Avatar
Thumbs up
we use atf /paint thinner 50/50
we spray it on all the stored parts great rust inhibitor and pest control
Old Aug 30, 2012 | 07:08 PM
Huneycutt's Avatar
That's fascinating. I've always followed the old practice of using ATF to clean the cylinder bores before re-oiling and installing pistons. Will definitely have to try this out.
Old Aug 31, 2012 | 04:31 PM
Gorts 5th's Avatar
Smile
we use it to hone the cylinders my last motor we used it to store it over might as an anti corrosive all our stored motors / parts are sprayed with the stuff we love it s we also noticed with regular spraying a nice coating builds up this is help full for us with our environment
screww wd 40 **** evaporates we dont use it at all or any other for that mater
Iowan
Apr 15, 2015 12:38 AM
dzltd02
Oct 28, 2008 08:25 AM
oilplanet
Mar 29, 2008 11:08 AM
robertoil
Jan 25, 2008 05:34 PM
