Please Please Help Valve lash
Old Oct 7, 2009 | 08:54 PM
DUST360's Avatar
Junior Member
Exclamation Please Please Help Valve lash
I can not either grasp how to set my valve lash or any getting the wrong info. I have a stroked 408 small block with adjustable roller rockers. please give me advice on how to set zero valve lash. its a hyd cam. And I would love to drive my car this year. thanks for everyones time. Mopar or no car:confus ed::confus ed:
Old Oct 8, 2009 | 04:26 AM
Polaradude's Avatar
Comp Cams tech sheet
Remove The Mystery From Properly Setting & Adjusting Valve Lash
Regardless of the type of camshaft you are running (hydraulic vs. solid, flat tappet vs. roller, etc.), properly setting the valve lash – the clearance between the rocker arm and valve stem tips – is a critical step toward achieving maximum power and durability. When most people think of setting the valve lash or “running” the valves, they think of it as a highly-involved, difficult procedure which involves an engine builder or educated professional of some sort. This is not true. The process is quite simple, and it’s something that you can do in your own garage. No matter if your engine is foreign or domestic, 4-6-8 cylinders, this walkthrough will make properly setting the valve lash with a solid or hydraulic camshaft seem like a walk in the park.
We’ll start with rocker arm installation. Assuming the pushrods have been installed through the guide plate into the lifter socket and they are centered, thoroughly wash each rocker arm and its accessories with soap and hot water or denatured alcohol (lacquer thinner) – then blow dry. Note: It is recommended that all pushrods be pre-oiled through the pushrod holes.
Next, apply a small amount of COMP Cams® assembly lube to both the valve stem tips and the rocker arm’s pushrod seats. Now you can install the rocker arm on the rocker stud. Apply a generous amount of COMP Cams® assembly lube to the rocker arm ball and position it on the rocker, with the flat side of the trunnion facing up. Make sure the pushrods are seated correctly in the lifters and the rocker arm seats. Use this exact process to install each and every rocker arm. DO NOT ROTATE THE ENGINE YET. THIS CAN RESULT IN BENT PUSHRODS!!!
With the stud properly lubricated, install the adjusting nut, but DO NO TIGHTEN it before going through the proper sequence of lifter adjustment. Tighten the nut with your fingers once the pushrod has no lash, but will still spin with your fingers. Repeat this process until all pushrods are seated and all rocker arms are installed.
Now, it’s time to set the valve lash. The most important thing is to make sure you do one cylinder at a time, starting at the #1 cylinder and working your way around. After installing the dampener bolt back into the crankshaft, turn the engine over by hand in the direction of its normal rotation.
This image displays the proper camshaft/lifter position to adjust
the valve lash on the intake.
HYDRAULIC LIFTER CAMSHAFTS
When the exhaust valve just begins to open on the #1 cylinder, adjust the #1 intake valve by loosening the adjusting nut slightly while spinning the pushrod until you feel lash in the rocker arm. Tighten the adjusting nut until the slack is taken out of the rocker arm and pushrod. Lightly turn the pushrod with your fingers as you tighten the adjusting nut, and you should feel a point where there is a little resistance. This is called zero lash – the point where you have taken all of the excess slack out of the pushrod. Turn the adjusting nut ½ turn past this point, giving you optimal pre-load for the rocker arm, pushrod and lifter. Follow this procedure by carefully adjusting each intake valve according to cylinder firing order.
Next, we’ll adjust the exhaust valves. To do so, you need to turn the engine over until the intake pushrod moves all the way up. Rotate just past maximum lift, where the intake will begin to close. The lifter is now at the base circle, and the exhaust valve can be adjusted. Note: DO NOT go too far down (over halfway) past the point of maximum lift. If you go too far, you will be in the overlap cycle – where intake valve lash is being taken up as the exhaust valve begins to open.
Rotate the exhaust pushrod with your fingers and begin to tighten the exhaust adjusting nut. When you begin to feel resistance against the pushrod, you are once again at zero lash. Tighten the adjusting nut another ½ turn. DO NOT OVERTIGHTEN. Repeat through the firing order until the lash on every exhaust valve has been set.
Now it’s time to double check, starting with cylinder #1. When the exhaust begins to open, check the intake. New hydraulic lifters shouldn’t be pumped up yet, so you should be able to spin the pushrod with some resistance. Think of the hydraulic lifter as a shock absorber – and you want to be right there in the middle of it. Until you have oil pressure, you’ll be able to push the lifter plunger into the bottom of the lifter. At that point, the lifter becomes solid. It might help to mark each rocker that has been set and then mark again each one that has been checked, giving the ones that are 100% finished a big “X” on the rocker arm body.
SOLID LIFTER CAMSHAFTS
Once again, the most important part is to remember to adjust just one valve on one cylinder at a time – starting with #1 and working your way through the firing order. To begin, check the spec card that came with your cam for the correct valve lash specifications. All COMP Cams® valve lash settings are “hot” settings, but will work for initial start-up as well.
Proper adjusment of the # 1 exhaust valve.
Rotate the crankshaft by hand until the exhaust valve begins to open on the #1 cylinder, adjust the intake valve by loosening the adjusting nut slightly until you feel lash on the rocker arm. Now you can set the lash on the intake valve. Spin the intake rocker nut down with the correct thickness feeler gauge inserted between the valve stem and the tip of the rocker arm. Tighten the adjusting nut until there’s a slight drag when moving the feeler gauge. DO NOT OVERTIGHTEN. After setting the lash on the #1 cylinder intake valve, put a magic marker across the top of the rocker to assure yourself it has been adjusted. Following this procedure, carefully adjust all intake valves.
To adjust the exhaust valve, rotate the crankshaft until the intake pushrod opens the valve all the way on the #1 cylinder and then begins to close (about ½ the way back down). With the correct feeler gauge, adjust the exhaust rocker nut using the same procedure as with the intake rocker above. Repeat for each cylinder, marking each rocker arm once it has been adjusted.
After setting your valve lash with the engine cold, it’s time to start it up and break it in to achieve normal operating temperatures. Due to thermal expansion, your valve lash should be tighter. Repeat the entire adjustment process to ensure your valve lash matches camshaft specifications, once again marking the rocker arm that have been adjusted. When finished, the rocker arms should all have an “X” mark on them – one mark for the first adjustment, another for the second.
Need Help? Contact COMP Cams CAM HELP at 1-800-999-0853 or email your tech question here
Old Oct 10, 2009 | 06:50 AM
rr69half6bbl's Avatar
polara, wow babe, right on the mark. through all that though i have 1 small question. Do your fingers hurt more from the typing, or do you have a headache from looking at the screen? lol
Old Oct 10, 2009 | 03:08 PM
MrOldart2U's Avatar
Nagh he prol'ly did it like I would have....(copy and paste)
Old Oct 10, 2009 | 09:33 PM
scotts74birds's Avatar
My 2 cents? If I had the damper off for the cam change, I would use the opportunity to use a timing tape on it. But we all know that it doesnt stay on. We glue panels of the car together where I work, but the glue on timing tape is only as strong as a post-it note! I dont get it. Anyways the point of this is to say that if I were adjusting valves, I would use a timing tape and then use a cold chisel to mark my damper every 90 degrees so that I could line it up at TDC every time. One cylinder is at tdc every 90 deg, might as well mark the damper for it.
Old Oct 11, 2009 | 07:15 AM
Polaradude's Avatar
Or if ya wanted to be really accurate get a degree wheel and a dial indicator.
and yes I am all about the cut and paste.
Old Oct 11, 2009 | 09:54 AM
deadkelly's Avatar
clean ya damper with wax & grease remover let it dry then put your timing tape on then use clear paint or clear nail polish done
74Runneer
Oct 17, 2015 10:32 AM
Mrpyro187
Nov 16, 2012 09:09 AM
Mr. Belvedere II
Jun 21, 2012 09:52 AM
Manoharvalves
Sep 15, 2011 10:53 PM
smackhonda
May 14, 2010 05:30 AM
