power steering pump
Old Jan 31, 2014 | 10:14 PM
raycan2's Avatar
power steering pump
Seems like water got in my powere steering pump...how do you flush it out? This is on a 440
Old Jan 31, 2014 | 10:17 PM
Add fluid while the return hose is held in a bucket, when it comes out clear your set.. Re connect and top up fluid
Old Feb 4, 2014 | 07:36 PM
Silverick's Avatar
X2
I lost a power steering pump from water in the fluid within a few hours of driving...
It was dark, I added fluid at my brother's place in Moorpark, from an uncapped container that must've been outside in the rain then, got on the freeway to go to Sacramento. The pulley locked up in Stockton... :-(
Old Feb 4, 2014 | 07:52 PM
raycan2's Avatar
No it did not lock up it just all of a sudden after starting the engine the wheels would turn to the left on its own. I know their is an adjustment on it I just have not messed with it still trying to fix the rear main seal leak.
Old Feb 7, 2014 | 08:10 PM
moe7404's Avatar
warring!!! do NOT use solvent or gasoline, or other thin fluids, they WILL make it lock it up. only use power steering or engine oil.
Old Feb 8, 2014 | 02:29 AM
raycan2's Avatar
I am thinking about just changing it out and putting in a Manual steering box.I was reading in a magazine that little things like that will rob HP from you motor.
Old Feb 8, 2014 | 02:58 AM
Keep the power steering !!! Manual steering is a "B".. most of the boxes out there are worn out. so unless you buy a a re manufactured FAST ratio box it is a waste of time. Even NASCAR uses power steering
Turning to the left ? You may have hit the top adjustment part knocking it out of adjustment when the engine was out ??
66Newport
Apr 22, 2013 04:43 PM
cork1958
Sep 10, 2012 02:45 AM
1968polara383
Jan 8, 2012 07:45 AM
brucewon
Apr 11, 2010 08:49 AM
heminate
Aug 17, 2009 08:07 PM
