Power steering pump rebuild
Old Apr 22, 2013 | 10:03 AM
66Newport's Avatar
I have a 66 Newport with 383. The power steering pump (with reservoir) is leaking from the stem were the return hose connects at the pump body. Can that stem be removed and the seal replaced?
Thanks in advance for your help.
Old Apr 22, 2013 | 02:55 PM
If you have the pot belly one then I say no. Cause I believe that it is soldered to the body. Just get you a rebuilt one at a good auto parts store.
Old Apr 22, 2013 | 04:43 PM
What you need to do is take the reservoir off and clean it very good and have someone braze the fitting. Baring that use a propane torch and some silver solder to repair it.
RockAuto has your seals GATES Part # 351160 Power Steering Repair Kit; Pump Seal Kit
raycan2
Dec 15, 2013 09:49 PM
cork1958
Sep 10, 2012 02:45 AM
1968polara383
Jan 8, 2012 07:45 AM
brucewon
Apr 11, 2010 08:49 AM
heminate
Aug 17, 2009 08:07 PM
