pre-magnum block fit with roller cam?
Old Jan 31, 2011 | 03:46 PM
bugy's Avatar
Question pre-magnum block fit with roller cam?
I wanna know if i can use a roller cam into a pre-magnum block (LA engine) i know they use flat tapped.
does anybody know??
Old Jan 31, 2011 | 05:38 PM
condor74's Avatar
You can use a roller in them just fine. LA engines were using roller cams before the Magnums came along. If your motor was not an original roller cam motor you will have to go with an aftermarket set up which usually has links that link the roller lifters together to keep them strait. If it was originally a roller cam motor just use the stock style lifters and retainer plates.
Old Feb 1, 2011 | 08:51 AM
bugy's Avatar
thanks for supporting
maca
Apr 17, 2015 08:02 PM
maca
Jul 12, 2014 08:45 PM
moparjohnson123456
Jun 14, 2011 01:28 PM
ellisfan
Feb 15, 2011 04:26 PM
norcalmopar
Aug 6, 2010 03:51 PM
