Question about mini starter on a 440.
Old Mar 2, 2010 | 04:11 PM
67gtxclone's Avatar
Is there some process defined for installing a mini starter? It seems like there is some room for adjustment as opposed to just a direct bolt in application. I mean, do you bolt the starter on and try it and if it makes noise, you just slide it further in?
Old Mar 2, 2010 | 08:02 PM
62Furious's Avatar
why a mini starter?$$$ never used one. a factory starter has always worked for me
Old Mar 2, 2010 | 08:12 PM
67gtxclone's Avatar
The mini starter was already with the car and it looks like new, so I was just going to use what I had. I did not take it apart, so I did not see how it was installed.
Old Mar 2, 2010 | 10:35 PM
toad490's Avatar
A factory starter won't work with some headers, my TTIs for example. 2 1/4" tubes. Also lighter.
Old Mar 3, 2010 | 02:08 PM
my guess would be to line it up the best you can
and if it grinds or does anything weird, adjust it
Old Mar 3, 2010 | 03:06 PM
scotts74birds's Avatar
Is it one of the later mopar starters from a Dakota and such, or aftermarket? I dont like the ones with the unsupported shaft, ie. no nosepiece. I feel they can deflect and cause flywheel damage, as happened on my Cheby. A yellow paint pen, or other hi-vis marker should tell you the engagement pattern of the teeth. http://www.popularmechanics.com/how_...31.html?page=2 http://www.performanceracingwarehous...Flexplates.pdf Here a few things I found.
Old Mar 3, 2010 | 05:25 PM
67gtxclone's Avatar
Thanks for the suggestions guys. I am not sure of the bramd or part number of the starter, but I will look when I go work on the car again this Saturday and let you all know.
Old Mar 4, 2010 | 05:28 AM
62Furious's Avatar
I know that the starter is lighter but did not know about big tube headers, gtxclone doesn't look like he is building an all out race car, thanks for enlightening me
Old Mar 12, 2010 | 11:25 AM
Morrigan_Aria's Avatar
Hell kitten
I'm ordering TTI headers and Mancini Racing said I'll need to buy a mini starter too, for a couple reasons.
1. Clearance issues. The headers are tight and so a mini starter simply gives you more room.
2. Heat issues. With the added clearance, you get some added cooling in there. Apparently the large headers cook the factory starter, making it difficult to start back up sometimes after driving a bit.
3. David said I'll cuss less (he doesn't really know me) if I use the smaller starter.
I'll ask Mancini about fitting it up, since they are calling me back shortly.
98 SNAKE EATER
Nov 15, 2013 06:32 PM
Hemiman
Jun 30, 2013 08:59 PM
redspowerjams
Jul 4, 2010 09:10 PM
BHertz
Jul 30, 2009 07:03 PM
hypermite
Mar 13, 2009 03:16 PM
