radiator
Old Nov 24, 2009 | 09:28 AM
sgp7679's Avatar
Question radiator
are there any radiators that will work with a 1965 coronet? i need one but cant find one, so i was thinking of getting one off of a more common car i can find. or does anyone have one for sale?
Old Nov 24, 2009 | 01:51 PM
Polaradude's Avatar
If you aren't going to get the one you have re-cored, measure the dimensions of the rad and note mounting points and go to a rad shop and hit the books.
Old Nov 24, 2009 | 03:13 PM
what is wrong with the one you have?
Old Nov 24, 2009 | 04:29 PM
sgp7679's Avatar
well a friend tried welding a crack it had but the torch was too hot and it melted some small tubes on the bottom of the rad.
Old Nov 24, 2009 | 06:16 PM
you could go the aluminum route
or you could have it re-cored
Old Nov 25, 2009 | 02:14 AM
theomahamoparguy's Avatar
try an M-body (diplomat, fifth ave etc.) youll have to make it work though. wont be an exact matchup.
Old Nov 29, 2009 | 02:46 AM
rr69half6bbl's Avatar
If you use an oddball rad, when you install it, be sure to have a few buddies help you . they need to hold it at each end and you need to put the fan shroud on and center it on the cooling fan, this is a must. or you wont get the cooling system to operate properly. and chew the shroud up. First make sure that the hosse inlet and outlet are in the same location,. after 72. they changed sides on the bottom hose.
gotdust
Jul 9, 2010 03:23 PM
Dust'em
Apr 8, 2009 04:49 PM
plymouthrr1985
Apr 1, 2009 03:29 AM
vitaminc383
Jul 20, 2008 04:00 PM
vitaminc383
Jul 19, 2008 08:20 AM
