Radiator for my '69 Roadrunner?!?
Old Sep 24, 2012 | 06:09 AM
Choppers383RR's Avatar
I am having a problem finding a radiator for my '69 Roadrunner ?!?! Its a 22" wide core, 383ci 4 speed, center cap and both upper and lower hose are on the left side!?! Please any help is awesome!!!!!!!!!!!!! The radiator in it now is a OEM one out of a C body 383 #2998963, my shroud will not fit ?! Thank you in advance))
Old Sep 24, 2012 | 10:10 AM
Archer's Avatar
chopper -
If you want factory, you may have to find an old unit it decent shape and have it rebuilt (new core, tanks cleaned).
If you want to keep the engine cool, just go with an aftermarket aluminum radiator. Yes, it will make a difference. And you might need to fabricate something for the shroud.
The upper hose can go on either side, you'll just need a hose with the right bends, if you don't use a flex hose.
Old Sep 24, 2012 | 11:42 AM
Got an OEM for $317.00 (^^^)
Old Sep 24, 2012 | 02:41 PM
Are not the inlet and outlet suppose to be on opposite side // The Water pump housing was used WITH THE LOWER OUTLET on either side depending on year
Old Sep 24, 2012 | 03:40 PM
1968-1969 they were on passenger side but the top one was closer to the middle than to the side. I have a factory 22" three row radiator.
Old Sep 24, 2012 | 06:19 PM
Archer's Avatar
TV -
While that does seem logical, apparently not always ...
Old Sep 25, 2012 | 05:05 AM
Plymouth Road Runner, 1966-69 V8 BB Radiator
NOTE: 22" Wide Core
FOR PART NUMBER AND PRICING, SEE BELOW.
Make / ModelPlymouth Road RunnerYear(s)1966-69EngineV8 BBNotes22" Wide CoreMaterialCopper/BrassAvailable CoresStandard Automotive
High Efficiency
OptimaCore Size18-1/8 x 22Available Rows3,4Cooler Size10x1/8 NPTFlow TypeDownflowInlet Size1-1/2"Outlet Size1-3/4"
Email to a Friend | Add to Compare
Old Sep 25, 2012 | 05:06 AM
That the radiator with the inlet and outlet on the left side that my RR came with!
Old Sep 25, 2012 | 08:35 AM
That looks the same as my factory one except mine has the mopar part number and penestar on it.
Old Sep 25, 2012 | 10:20 AM
thought you said they were on the passenger side..now you say its the same as yours..Im confused??
Choppers383RR
Sep 24, 2012 11:41 AM
gotdust
Jul 9, 2010 03:23 PM
plymouthrr1985
Apr 1, 2009 03:29 AM
vitaminc383
Jul 20, 2008 04:00 PM
vitaminc383
Jul 19, 2008 08:20 AM
