Radiator for my '69 Roadrunner?!?
I am having a problem finding a radiator for my '69 Roadrunner
?!?! Its a 22" wide core, 383ci 4 speed, center cap and both upper and lower hose are on the left side!?! Please any help is awesome!!!!!!!!!!!!! The radiator in it now is a OEM one out of a C body 383 #2998963, my shroud will not fit ?! Thank you in advance))
chopper -
If you want factory, you may have to find an old unit it decent shape and have it rebuilt (new core, tanks cleaned).
If you want to keep the engine cool, just go with an aftermarket aluminum radiator. Yes, it will make a difference. And you might need to fabricate something for the shroud.
The upper hose can go on either side, you'll just need a hose with the right bends, if you don't use a flex hose.
Plymouth Road Runner, 1966-69 V8 BB Radiator
NOTE: 22" Wide Core
FOR PART NUMBER AND PRICING, SEE BELOW.
Make / ModelPlymouth Road RunnerYear(s)1966-69EngineV8 BBNotes22" Wide CoreMaterialCopper/BrassAvailable CoresStandard Automotive
High Efficiency
OptimaCore Size18-1/8 x 22Available Rows3,4Cooler Size10x1/8 NPTFlow TypeDownflowInlet Size1-1/2"Outlet Size1-3/4"
Email to a Friend | Add to Compare
NOTE: 22" Wide Core
High Efficiency
gotdust
Jul 9, 2010 03:23 PM
vitaminc383
Jul 19, 2008 08:20 AM
